PCIII/Andrews 26H map needed
Old Jul 6, 2009 | 12:39 PM
stro1965's Avatar
stro1965
Default PCIII/Andrews 26H map needed
I'm currently running a T-Max, but having some issues getting my bike to idle properly since a cam swap. Love the T-Max, it's worked great for 18,000 miles, but I'm now frustrated with it. I've tried just about everything I can think of and can't fix it. Zippers hasn't been able to fix it either so far. If I were to give PCIII a try, does anyone have a basemap for a 2007 96" touring bike with SE A/C, V&H Propipe and Andrews 26H cams?
I spoke with Jamie at Fuel Moto and he said he thinks his maps for the 26H were all made for slip-on muffs. If I could be reasonably assured that a map exists for my needs I might be willing to try a Power Commander. Hate the thought of putting my bike on a dyno, just a personal thing.
Anyone?
Old Jul 6, 2009 | 01:45 PM
Foley Fats's Avatar
Foley Fats
Have you thought about putting your stock ECM back on and tuning it with the TTS Mastertune?
Old Jul 6, 2009 | 02:48 PM
stro1965's Avatar
stro1965
No, I know absolutely nothing about it and would rather not have to dyno my bike.
Old Jul 6, 2009 | 07:15 PM
jeffer60's Avatar
jeffer60
Default curious
Stroh, sorry to hear about your tmax troubles. You have been helpful to me in the past with my concerns. What is the TTS Master tuner?
Jeff
Old Jul 6, 2009 | 07:41 PM
iclick's Avatar
iclick
Anyone?
I would definitely buy a PCV over a PCIII for a number reasons, the most compelling being that it is compatible with Auto-Tune if you decide to go that route in the future. Fuel Moto has PCV "retrofit kits" that will work fine on your '07 as it does on mine.
If there's a doubt about whether or not a good map is available for your configuration from Fuel Moto I would consider just springing for AT at the outset. That way you're covered and likely won't require dyno-tunes for the duration regardless of how your setup changes in the future. If you buy the PCV and require a dyno tune to get a correct map you might as well spend $300 on AT instead.
Old Jul 6, 2009 | 07:42 PM
skydoc's Avatar
skydoc
Hate the thought of putting my bike on a dyno, just a personal thing.Anyone?
Get over it...best bet is a dyno tune!
Old Jul 6, 2009 | 09:50 PM
Foley Fats's Avatar
Foley Fats
The TTS Mastertune allows you to tune your bike yourself, using a laptop computer to collect data as you ride, using your stock O2 sensors.
Go to the ECM tech section of this forum and you will find a long thread on it.
There are a lot of happy users with it.
txphatboy
Exhaust System Topics
Dec 10, 2012 09:16 PM
01ragtop
Jun 26, 2011 01:31 PM
brettnbama
Jan 5, 2011 05:26 PM
JR-Boston
Apr 26, 2010 04:16 PM
Molzy
Dec 19, 2009 08:22 AM
