Funny "thud" 09 Ultra
Old Jul 7, 2009 | 09:32 PM
Conehead's Avatar
Conehead
Default Funny "thud" 09 Ultra
Anybody experience a thud when hitting some rough spots in the road, almost like the tire does not have enough air in it and the rim is hitting. I have checked the air in the tires and the shocks. It does not happen often but when it does it is concerning.
Old Jul 7, 2009 | 10:05 PM
Mountainkowboy's Avatar
Mountainkowboy
Possible, bottoming out.
Old Jul 7, 2009 | 10:06 PM
ranman469's Avatar
ranman469
do you have enough air in you rear shocks??
Old Jul 7, 2009 | 10:12 PM
Harpoonman's Avatar
Harpoonman
Originally Posted by Conehead
Anybody experience a thud when hitting some rough spots in the road,...
Yes I have. I wasn't sure if the shocks were bottoming out on the frame or if , as you said. Depressing the tire drasticly and hitting the rim. I increased my rear shock air pressure (with passenger) to 43 to 45 psi. Solo I run 38 to 40 psi. I don't hear as often. Don't know if the air pressure was the trick, or if I'm just blocking it out. I check the psi before each ride or every three days. I do it that often because I have a leak. I told the dealership about it on my last scheduled service....but it still leaks. I plan to use some soapy water to find the leak, but haven't taken the time yet.
Old Jul 8, 2009 | 09:19 AM
Conehead's Avatar
Conehead
Thanks for the replies, I have checked the tire air and the air in the shocks. I will try adding some air in the shocks. HarpoonMan you described it to a tee, at least I know I am not the only one with the issue.
Old Jul 8, 2009 | 11:34 AM
Jags93's Avatar
Jags93
I also experienced this and don't believe it bottomed out. in both instances I hit a manhole sunk about 2". I think it would have been more abrupt if I did bottom out but definitley a good thud. I'm running 16psi in the shocks riding solo at 170lbs.
Old Jul 8, 2009 | 11:44 AM
cbears's Avatar
cbears
Had a similar noise. Bumped the air pressure in the shocks. I think that was it for me.
Old Jul 8, 2009 | 12:05 PM
n8dc's Avatar
n8dc
prolly the broken frame rubbing together on the bigger bumps ...
just kidding
Old Jul 8, 2009 | 12:14 PM
Bowhunter61's Avatar
Bowhunter61
Is this a metal to metal thud or more of a deeper tone? Also is it in the front end or Rear (if you can tell)? I have a "cluck" in the front end when hitting bumps, not all the time, it seems to be I have to hit the bumps jsut right.
Old Jul 8, 2009 | 01:59 PM
Conehead's Avatar
Conehead
Mine feels like the back tire is low on air and the rim is contacting the road.
