Seems to me that once the bike is done priming the fuel system you then immediately being to lose fuel pressure. Starting the bike while late in the priming phase gives the highest fuel pressure and hence a quicker start. I dunno. My bike may not start quicker but I certainly have much fewer bad starts when I start while the bike is priming.
I know this for a fact . I have seen it said here. I have done it myself. If you push the stater button as soon as you turn the ignition on it will start quicker than if you wait for all the "idiot" lights to go out. Which does not make sense to me. It seems if all the lights are out and everything is programmed to go it would start quicker than when all the lights (indicaters) are still on. Would someone less ignorant than I please explain this phenomenon. Thanks. OLD 96.
This is a know issue with power commanders. No big deal, just start it up before the engine check light goes out.
My nieghbor has an 07 and starts it right away. He was having an issue with the starter kinda "skipping" when he waited on the light. Now it NEVER "skips" He thinks the small amount of drain on the battery waiting although it is VERY minimal it must be enough to drag the starter down.
sounds like lots of speculation on all of our parts. I was told by the salesman to wait. I haven't seen a problem in doing this. The bike always starts right up. I wish someone who really knew would chime in and let us know. I did notice the time I had the bike in the shop that the tech just started it right up. Who knows.
I have a 98 Road King (EFI) and all you need to wait for is the fuel pump to get up to pressure before hitting the start button. That is way before the idiot lights go out. You should be able to hear it when you turn on the ignition.
As stated above. Definitely the case with my PCIII. Believe someone on this forum said it wasn't the case with the PCV. So, Old 96, do you have a Power Commander???
The diagnostic check that is being done when you first turn the ignition switch on will finish with or without the bike running. It will not hurt the bike in any way shape or form to start it before the yellow light goes out.
This is true. It is also true that neither my owner's nor service manual says anything about waiting.
This is covered in the SERT manual. Somebody posted it on here before. The theory behind the difference in starting immediatly and waiting for the light goes out is that there is one pulse of fuel that goes into the motor as soon as the ignition switch is turned on. Especially if the motor is hot, that fuel will vaporize or dissapate before the light goes out.
I didn't know that, so thanks for sharing it! My bike (TC96 with SE255's) starts better without waiting.
BTW, how do find gas that will run in that bike without detonation?! I didn't know it was possible to run SE255's and 10.5 CR in the same bike on pump gas.
if the manual says to let the idiot light go out before starting to avoid potential problems, I can live with that.
i'm not sure on the newer manuals, but i can tell you that the 07 manual does not mention that you have to wait for the light to go out before starting. if you read it, it does mention that it will take 3-4 seconds before the light goes out, but not that you have to wait.
and because i have a pciii, i get that hard start feature, so what i do is turn the ignition on, let the computer cycle through its checks, then hit the run button, wait 1-2 secs for the fuel system to prime, then hit the start button. fires right up, been doing it this way for 3 years now and no issues.
My bike starts immediately when i hit start, whether I wait for the light to go out or not. So I figure, if the experts (MOCO) say to wait for the light to go off why not wait? I'm pretty sure they know what they are talking about and have a reason for it.
