Lever swap
Old Jul 16, 2009 | 12:02 PM
rome304's Avatar
rome304
Default Lever swap
looking in service manual could'nt find section to change out levers looks simple but it's the simple jobs that end up pia thanks for any help.
Old Jul 16, 2009 | 12:06 PM
07RoadHawg's Avatar
07RoadHawg
Really easy. Remove snap ring, push pin out and remove lever (after you loosen the slack aduster on the clutch cable). Reverse to install. There is a part in the instructions that reference putting a thin piece of cardboard on the brake lever side to release the pressure on the stop light switch tab. I never have done that and never had any problems (knock on wood) although some here have reported breaking off the tab on the light switch.
Old Jul 16, 2009 | 12:07 PM
03dragonRK's Avatar
03dragonRK
Very easy. Pull snap ring of the bottom of the pin - pull pin and swap levers lub pin and reinstall pin and snap ring.
Old Jul 16, 2009 | 12:11 PM
kingofsand21's Avatar
kingofsand21
yeah, what they said its easy. If you go to sears you can get a pair of snap ring pliers for under 10$ dont need them but they come in handy for other things too. like replaceing clutch cable and such.
Old Jul 16, 2009 | 12:20 PM
rome304's Avatar
rome304
thanks guys it looks easy just wanted to make sure appreciated.
Old Aug 6, 2009 | 10:25 AM
rome304's Avatar
rome304
Thanks again got it done last night.
TeeStu
May 31, 2015 01:25 PM
Brucewrs
Jun 5, 2014 10:55 PM
HDDyna2006
Sep 11, 2008 07:13 PM
blacked out
May 19, 2008 10:48 AM
kato1964
Apr 21, 2007 01:46 PM
