Fly by Wire throttle tension adjustment
Old Jul 16, 2009 | 11:48 PM
MI_Jim's Avatar
MI_Jim
Default Fly by Wire throttle tension adjustment
A buddy of mine has an '08 Ultra Classic and is unhappy with the throttle tension. He'd like to loosen it up a bit because his hand/wrist gets sore on long rides. Is there a way to do this?
Old Jul 16, 2009 | 11:51 PM
emwolb's Avatar
emwolb
has your friend who gets the tired hand or wrist learned how to operate the cruise control? it's an amazing device.
Old Jul 17, 2009 | 12:34 AM
vzts4q's Avatar
vzts4q
Originally Posted by emwolb
has your friend who gets the tired hand or wrist learned how to operate the cruise control? It's an amazing device.
+1000
I have a 08 Ultra and don't find the tension that hard at all. And I have small hands and am the + side of 60
Old Jul 17, 2009 | 12:39 AM
RKKY's Avatar
RKKY
Gonna have jump on the cruise control bandwagon here as well. Went on my first long distance ride with cc over the 4th of July weekend. Not sure how I ever lived without it for the last 15 years. But to answer your question; I do not know of anyway to change the tension on the TBW bikes.
Old Jul 17, 2009 | 02:39 AM
Potatobudvs's Avatar
Potatobudvs
Only if it works...which mine either does or doesn't depending on the day. Dealer says it's working fine tho :P
Old Jul 17, 2009 | 05:00 AM
up2nogood22's Avatar
up2nogood22
I can't find one in the service manual. I would love to tighten mine up. Mine is so loose I hate it. Have to use my thumg against the housing to create my own friction....
Old Jul 17, 2009 | 05:28 AM
rocknrod's Avatar
rocknrod
Or get a throttle boss that he can lean his palm on.
Or a set of Kury Grips with the throttle boss installed.
I have that and cruise.
He probably needs to loosen up his grip. You hold it too tight, after a while you get pain (no comments from the peanut gallery).
Old Jul 17, 2009 | 09:38 AM
ftanner's Avatar
ftanner
If I remember correctly, there is a spring controlling the tension in the TBW induction module in the handlebar. There may be a way to replace that spring.
Old Jul 17, 2009 | 10:56 AM
timvan's Avatar
timvan
I dont think it comes apart... if it did, id bet you would find codes poping up once it was reinstalled
Old Jul 17, 2009 | 11:12 AM
Watchfuliz's Avatar
Watchfuliz
Throttle Rocker........worth every penny.
