Cut down stock windshield
Old Jul 18, 2009 | 07:47 AM
SE120RG's Avatar
SE120RG
Default Cut down stock windshield
Anyone have any tips on cutting a couple inches off a stock windshield. What tool works best etc?
Old Jul 18, 2009 | 07:59 AM
glebo's Avatar
glebo
Well...I've seen it done this way, didn't booger it up to much.
Measure where you want to cut, put masking tape (or something similar) on both sides of the windscreen, then use a very fine saw blade (jig or hack saw) and start cutting, make sure your windscreen is very stable/secure. You can smooth out the edges with some very fine emry cloth/sandpaper and polish it if need be with some very fine buffing compound and maybe even toothpaste.
I've seen a dremmel tool used once, but it went so fast it melted the plastic along the way and was harder to clean up, maybe some one knows the techinque, but I would do the saw thing.
Don't hold me to it, but it worked at that particular time.
raceframe's Avatar
raceframe
I have done quite a few with a fine tooth blade,16/ 18 tooth, on a band saw with excellent results.I am sure it would work well with hand held jig saw provided you have a steady hand and good work surface.I used masking tape to cover the windshield surface to protect it from scratches and draw my cut line,then finish it off with a sanding block and some 80 grit paper.
Old Jul 18, 2009 | 08:17 AM
Gordon65's Avatar
Gordon65
rotozip works great too.
helped a friend cut his, taped it all up, drew the line, etc...he has a steady hand, and the cut turned out great. block sanded with some 400, and you couldn't tell it was cut down.
Old Jul 18, 2009 | 10:59 AM
SE120RG's Avatar
SE120RG
thanks guys
Old Jul 18, 2009 | 11:15 AM
MILO851's Avatar
MILO851
I cut one from the bottom with jig saw. a little more intricate cut but it hides the cut in the fairing. Then i wasnt worried about the edge.I was also hidding some holes someone had drilled to mount something.
Old Jul 18, 2009 | 11:16 AM
KopperTop's Avatar
KopperTop
If you're just taking a few inches off, don't cut from the top -- cut from the bottom! I did this a few times and it's easy and leaves you with the same smooth professional edge with no risk of screw up that's visible.
I traced the shape of the lower shield onto poster board, then cut that out as a template. Then I masked the bottom of the shield with painter's tape and with the posterboard template, traced the bottom contour onto the taped stock screen, exactly .75" above the bottom. Five minutes under a jigsaw with a fine-tooth blade, and the job was done. No need to finish the edges (they're all hidden), no polishing and a totally factory look.
Unless you're lopping 6 inches off the shield (the taper would make the shield too narrow at the bottom), I recommend cutting your shield off at the bottom. Super-easy. For me, 11.25" seems to be the perfect height to look over the shield without getting too much buffeting. YMMV.
madcardisease
Apr 18, 2012 10:10 AM
coachchris
Mar 20, 2011 03:40 AM
jetmech
Dec 6, 2006 04:04 PM
siramazing
Oct 23, 2006 12:01 AM
chunks
Jul 11, 2005 10:27 AM
