Hogtunes
Old Jul 28, 2009 | 11:37 PM
topdog1958's Avatar
topdog1958
Default Hogtunes
Anyone have any dealings with them. I am having problems with a system, amp upgraded speakers that I just bought. Not real happy with this system.Thanks for any help....
Old Jul 29, 2009 | 12:21 AM
cmhfguy's Avatar
cmhfguy
You didn't say it but I assume the items you are having probs with are from Hogtunes? Have you contacted them about your problems? Don't know what you are looking for from your post. I'd suggest contacting them and giving them an opportunity to respond.
Old Jul 29, 2009 | 12:28 AM
bazam9s's Avatar
bazam9s
Pez of Hogtunes is a top notch guy...always willing to help...call him and give him a chance to respond.
Old Jul 29, 2009 | 05:39 AM
bcerame's Avatar
bcerame
5th Gear
Default hogtunes
They are great to work with. Excellent follow up. I have speaker\amp upgrade and am very satisfied. Two problems I had. First, there is a fuse holder inline on the wire that goes to the battery. The fuse was loose in the box and not installed on min from factory. Second, they shipped some units out with an incorrect wiring harness. Called Hogtunes and they overnited it to me. Easy to follow install. Call or email them.
Old Jul 29, 2009 | 05:55 AM
HD Renegade's Avatar
HD Renegade
+1, you cant beat the service you get from Hogtunes, give PEZ a call, I am sure he will help you with the issues.
Old Jul 29, 2009 | 08:02 AM
topdog1958's Avatar
topdog1958
Thanks for your help. I will give Pez a call today. The systems does not sound crisp, sounds muted. I don't think the front speakers are strong enough to carry the amp.
Old Jul 29, 2009 | 08:18 AM
Bandit4142's Avatar
Bandit4142
Double check your speakers as well. On mine, the 902.2 were in the pods, and the new rear speakers were in the box. I had to switch them out. If I would have just pulled everything out of the box and installed it, the speakers would have been backwards.
Old Jul 29, 2009 | 08:27 AM
Northwoodz's Avatar
Northwoodz
Someone clarify this. There is NO WAY the POD has the same size speakers as the rear???? WTF is he trying to say?
Old Jul 29, 2009 | 08:30 AM
QSRYDR's Avatar
QSRYDR
I think he meant the pods to add the rear speakers to the tour-pak, NOT the tweeter pod.
Old Aug 13, 2009 | 01:53 PM
flyingace's Avatar
flyingace
You did not mention which Hogtunes package you have.
Did you do the Utrasound package, and if so, did you put the correct speakers into the rear pods as the instructions indicate? With the Ultrasound package, the speakers that ship in the pods, actually get taken out and mounted in the fairing, and the other speakers that ship with the kit get put into the rear pods.
If you did not do this, then that is your problem.
Rufnek100
Aug 10, 2018 08:15 PM
macabra11
Audio Systems
Sep 11, 2017 10:12 AM
mgordyan
Sep 15, 2016 07:23 AM
Aero993
Audio Systems
Nov 13, 2015 02:46 PM
b_townchops
Audio Systems
Mar 19, 2014 07:14 PM
