Windshield Keeps Coming Loose
Old Aug 1, 2009 | 07:20 AM
RaggedEdges's Avatar
RaggedEdges
5th Gear
Default Windshield Keeps Coming Loose
I changed the windshield on my 06 Street Glide to a taller version. I also added the chrome trim piece to the bottom of the windshield. The left corner of the windshield keeps coming loose and I cant figure out why. I put the washers in the trim piece like the instructions indicated and this one side still seems to work loose after a short period of time. The screw does not come out but it does get loose enough to make the windshield vibrate at slower speeds. anyone have any suggestions or expierienced the same problem?
MIKE
Old Aug 1, 2009 | 07:27 AM
ranman469's Avatar
ranman469
is the shield seated properly?
get some blue lock tite for the screws.
if that dont work , send me the chrome peace. lol
good luck
Old Aug 1, 2009 | 08:22 AM
Texas Fat Boy's Avatar
Texas Fat Boy
I'd say that side isn't set in properly. Wiggle the windshield while you tighten it up.
If it still doen't work replace that brass insert. It's a simple job or it's covered under warrenty if you want to go that way.
I wouldn't use lock tight (of any color) on the windshield screws.
Old Aug 1, 2009 | 09:23 AM
imrotton2's Avatar
imrotton2
you mite wanna try some fingernail polish on the screws,,, it will hold pretty good but is easy to break loose... you mite wanna check those faring mounts also,,, they are known to break
Old Aug 1, 2009 | 09:30 AM
budwfo's Avatar
budwfo
Check and see if the insert is coming out of the inner fairing on that side, i had this happen to my 06" Electraglide, the screw is tight but not holding the windshield firmly..
Old Aug 1, 2009 | 09:32 AM
krw's Avatar
krw
I used pipe tape. Very thin and easy to remove.
Old Aug 1, 2009 | 10:18 AM
unclzim's Avatar
unclzim
If you use loctite, you might want to let it dry before installing the screw. If the insert is coming out replace it with the new style that screws into the inner fairing.
Old Aug 1, 2009 | 11:34 AM
EastSideBikerTrash's Avatar
EastSideBikerTrash
MIKE
You said chrome trim piece. I don't recall using washers on it. Now the bar and shield trim piece has shorter screws and uses washers. Did you buy an aftermarket windshield? Some of them are thicker than the OEM windshields. This may your problem. The solution may be longer screws?
Dave
FireFighter200
2014-2024 Touring Models
45
Jun 2, 2019 03:46 PM
cmc seabee
Sep 22, 2012 01:09 AM
dboyenga
Apr 12, 2011 08:21 PM
1200babe
Feb 14, 2008 07:13 AM
Primo
Mar 14, 2006 12:41 AM
