408F squirrely?
Old Aug 3, 2009 | 12:03 AM
MNrider's Avatar
MNrider
Default 408F squirrely?
Is this tire a little squirrely? Maybe it just needs to be broken in more. Feels like it moves around a lot on the freeway. I have about 750 miles on it.
Old Aug 3, 2009 | 12:25 AM
oppirs's Avatar
oppirs
Is it the Front tire moving around or the Back?
Old Aug 3, 2009 | 12:38 AM
MNrider's Avatar
MNrider
I think it's the front. It sometimes feels like a driving on ice sensation. Maybe it's just the wind on the side on the fairing. But you never know with these touring tires.
Old Aug 3, 2009 | 04:57 PM
grbrown's Avatar
grbrown
Check your tyre pressure, both ends. They should only need a couple of hundred miles max to 'run in', but may settle a little, so need a bit more air. If you are heavy, or travelling two up, put your pressures up 2-4 psi, even a little more.
Old Aug 3, 2009 | 05:25 PM
MNrider's Avatar
MNrider
I'll check it out tonight.
Old Aug 3, 2009 | 05:27 PM
davewear's Avatar
davewear
no problem here, might be the first time i've liked the stock tires on a bike....
Old Aug 3, 2009 | 09:50 PM
MNrider's Avatar
MNrider
Yep, the front was 28psi. I'll try it tomorrow at 38psi and the rear at 42psi. Yes, I'm heavy. Thanks for the tip.
Old Aug 3, 2009 | 10:19 PM
Intrepid175's Avatar
Intrepid175
That's your problem! You weren't the first and you won't be the last to be bit by that one. Please let us know what you think after tomorrow's ride!
Ride Safe,
Steve R.
Old Aug 4, 2009 | 11:08 PM
MNrider's Avatar
MNrider
It's better but still a little loose feeling.
Old Aug 4, 2009 | 11:45 PM
iceman5218's Avatar
iceman5218
In my metz I would always run 40 psi. Can u do that and be food with the new rubber?
