PCV AutoTune and New Cam Question
Old Aug 4, 2009 | 08:56 PM
TexasVet's Avatar
TexasVet
Default PCV AutoTune and New Cam Question
I am looking at upgrading the stock cam in my 96 to either a SE 204, 255, or Andrews 26H. I have the PCV with AT that I purchased from Fuel Moto.
When I change the cam out on the bike will the AT tune the bike correctly for the new cam? I was understanding that when a cam is changed that the bike has to be dyno tuned and timing set appropriately. I called and talked to Fuel Moto and told the gentleman what I was wanting to do with regards to a cam change and he informed me that the AT will tune the bike for the new changed cam.
I asked him whether AT will change the time on the motor and he said no only the AFR. Also, that they did not have any base programs for a cam change but they could create something if needed.
So my question is whether the bike has to be dyno tuned for a base map then the AT to set the AFR correctly? Or am I missing something?
Old Aug 4, 2009 | 09:11 PM
OG1's Avatar
OG1
the AT has got you covered. it will be a pretty drastic difference in trims from my experience.
Old Aug 4, 2009 | 09:23 PM
Chimp's Avatar
Chimp
I'm quite sure the Fuel Moto guys will have a basemap for you. I would get that and load it on the PCV. The AT will then clearly trim to hit the right AFR.
But it's correct that the AT will NOT alter the timing at all. You'll need a basemap that already has that dialed in. I doubt you'll need a dyno as the map you get from Fuel Moto should be close enough.
Old Aug 5, 2009 | 05:16 AM
MODCOBRA's Avatar
MODCOBRA
subscribing
Old Aug 5, 2009 | 09:16 AM
rambler43's Avatar
rambler43
I had just the PCV on my 07 ultra and a map from Fuel Moto and the bike ran great,then i had HeadQuarters 500 cams installed and a new map from Jamie, at first i thought i wasted my money on the cams because not much of a change in power until i added the auto tune, after accepting trims a couple times the bike performs totally different, more power,throttle response and mileage.
My opinion is just add the cams and let auto tune do its thing
Old Aug 5, 2009 | 10:14 AM
deezee's Avatar
deezee
FM hooked me up with a base map for my 09SG when I dropped in the SE211. I rode the PCV with AT and accepted trims for about 500 miles before I took it into see where I was at on the dyno. Chris K at Bumpus HD in Jackson Tn did 4 pulls. Together we tweaked the PC on the dyno for about 5 minutes, and it yielded an extra 5HP and 3fpt. The AT was close, but the 5 minutes of smotthing things out on the dyno could really be felt......I could only imagine what a full tune would yield.
The AT actually tunes up really quickly so youll see positive results after the first couple of rides. Once you get comfortable with trimming and the tables, you can safely start experimenting with AFR tables and timing........
HAVE FUN!
Old Aug 5, 2009 | 11:07 AM
iclick's Avatar
iclick
You're getting good advice here, IMO. After swapping cams I would have Fuel Moto send you the closest map they have as a starter, then let AT do the rest. Ignition timing isn't as big a concern as you might think, as they are fairly similar between setups, and WOT timing for mine with 255's is the same as stock.
I did add some advance in the cruise range (2-3°) to increase mileage and cooling, and as long as I don't exceed this amount I get no detonation. That was one of the big surprises after upgrading cams since I expected a need to retard the timing a bit in the cruise range to compensate for the increase in CCP from the cams' early intake close (25°). It was quite the opposite as it turned out.
My theory is that the ideal settings at part-throttle are as high as it can tolerate during a roll-on. IOW, 4° causes light detonation but 3° does not, so that's my setting. I could sense no performance difference after making those changes to the cruise range, however.
You've made a good list of candidates, IMO, but be advised that the 204's and TW26's will likely hurt the low-end a bit using stock CR. The 255's will not and will give a nice boost from 2300-4500, although will likely give less peak HP (above 5k RPM) than the other two options. It just depends on what you're looking for.
Old Aug 5, 2009 | 12:14 PM
truckerdave's Avatar
truckerdave
senior experienced all-knowing leader of the unwise
Using SE 204's on a 103 with 10:1 compression i was able to advance the timing 4 degrees at WOT higher RPM's down to 1 degree advance at lower rpms with no detonation. I used some of the canned maps timing settings to start with. The autotune seemed to work fine tuning that combo. It will pull the front wheel off the ground. I'm sure i could get a horse or two more by tuning it on a dyno for power instead of mileage but i like getting 42 mpg average on a 800 pound touring bike. Seems like you could do the same thing with the autotune by setting the AFR's though.
Old Aug 5, 2009 | 01:28 PM
vtwinbmx's Avatar
vtwinbmx
The autotune will get your AFR spot on. You will need Fuelmoto to give you a map for timing. Or you will have to have a shop Dyno run your bike after your AFR is set and only tune your timing
Old Aug 5, 2009 | 01:33 PM
badjustbad's Avatar
badjustbad
iclick, this is not true. I have experienced no loss of low-end torque with my TW26 cam install. In fact I have experienced a significant increase in low-end torque. If you mean the 204's and TW26's have a different torque curve than the 255's, I agree. But unless you do a side by side comparison with the total package being identical (Intake, exhaust, gearing, etc.) you can't really claim one is better than the other.
Remember, cam lift and duration numbers don't tell the whole story, it's the whole package that determines how a cam affects each bike. If it was that easy, cam manufacturers would all simply create the perfect cam grind and nobody could claim their product is better than the other guys. It would save them a lot on advertising, though.
