PCV AutoTune and New Cam Question
I've always been careful not to suggest that the 255's are "better" than anything else, as the TQ curve of any cam may be good for one rider and bad for another. It's just that I don't think you can beat the 255's for low-end and midrange TQ with stock CR, but as I said you pay for it in the top-end. The 26's will undoubtedly produce more peak HP, and in a *****-to-the-wall drag race will likely pull a like-equipped bike with 255's. But for the ability to pass a truck with a fully loaded touring bike up a hill without downshifting, the 255's may be unbeatable.
I researched cams for about two years and talked to both Bob Wood and Andrews about their offerings. When I described what I was looking for, which was an increase in low-end and midrange TQ without moving the TQ curve to the right at the same time, Andrews said "We don't have a cam that will do what you want without a CR increase." He told me the 21's would make little difference over a stock TC96 and the 26's would definitely move the TQ curve to the right at the expense of the low-end. I thanked him and moved on. Bob Wood was high on the 6-6 with +4° gear, but despite the hype I never could find a TQ curve that produced what I was looking for except with bikes that had other mods.
After deciding on the 255's based on some dyno charts I had seen in stock TC96's, I did the job and the result was what I expected. That's all I asked for.
What takes the issue into another realm is CR, as when you start increasing CR the low-end weaknesses of most cams will start to disappear, how much depending on the grind. My statements were predicated on cams installed in a stock engine (9.2:1 CR and the usual Stage 1 components).
You're right that specs aren't the whole story, but I'm referring solely to bikes with stock CR. The 25° intake close and relatively mild duration result in a high CCP, and that is what makes torque. I could produce some dyno charts that show what I'm referring to, but I can't vouch for how good the tuner is with any of these builds, so I think charts may be irrelevant for comparing two different cams unless all other factors are equal, including an optimum tune for the setup.
What I am trying to point out is, when compared to a stock cam's torque curve the TW26's produce more low-end torque, not less. However I agree, some cams may produce more torque than the TW26's in the low-end on a given configuration (maybe the 255s, maybe not). As I said in my previous post, you need to compare identical configurations to make that claim and to my knowledge, that hasnt been done not even by the cam manufacturers.
Now, if you have personally installed and tested both the 255s and the TW26s on the same bike, I apologize for being out of line.
Like I mentioned before, I called Andrews and asked them about a cam recommendation to move my TQ curve up at least 5 ft./lbs. in the low-end and midrange but not shift it to the right, as well as no loss in the extreme low-end and no other engine mods, and was told "We don't have a cam that will do that." He said the 21's would make little difference over stock and the 26's would shift the curve to the right at the expense of some low-end TQ. The 54's might have been an option had I been willing to change springs, but I wanted a bolt-in for an otherwise stock engine (with Stage 1 additions).
. Correct me if I'm wrong, but compared to stock if a cam set has a later intake close and longer duration it will produce less TQ on the low-end. If you're not producing the CCP, which is reduced with a later intake close, I can't see how TQ can be equal or higher without increasing compression. There is no doubt that the midrange and high-end will be much improved, but I'm talking about the low-end, in this case 1800-2500. This is a very usable range for me, as I typically cruise there and want to be able to nail it and have the power available without downshifting.
