SE A/C Install ?
Old Aug 7, 2009 | 05:33 AM
Tx_Rider's Avatar
Tx_Rider
Default SE A/C Install ?
I just installed the Fuel Moto package, PC-V, Jackpots and an SE A/C kit.
My question is, the two bolts mounting the backing plate to the heads on the A/C, they have "O" rings on them and seal up the holes. I thought this was the crank case ventilation. Did I get the wrong kit or did I miss something? I dont see how the crank case vents.
Havent fired it up yet, got finished too late last night, wanted to check here before I ran it.
Old Aug 7, 2009 | 05:40 AM
rocknrod's Avatar
rocknrod
It is a vent. If you look at the stem that mounts to the heads (O-ring on the end) you will see it is hollow. Vents out to the intake side of the A/C unit.
Old Aug 7, 2009 | 05:52 AM
Pastor John's Avatar
Pastor John
Yep, what rocknrod said... I was surprised to see those little O-rings, but I suppose they are one more measure to keep grit from the motor or oil from escaping the crankcase ventilation feature.
Old Aug 7, 2009 | 10:56 AM
Tx_Rider's Avatar
Tx_Rider
Thanks for the reply, took it out for a spin after everything was put back together and cleaned up. Ran great, like a new bike.
Sounds and runs like it should now.
Old Aug 7, 2009 | 03:50 PM
hawg20's Avatar
hawg20
I had trouble keeping the o-rings in place while tightening the bolts. I damaged one. I took back off and use a little grease in the groove to hold the 0-ring in place, worked like a charm!!
Kuzmitch Davidson
Engine Mechanical Topics
Apr 9, 2018 09:23 AM
otto76689
Aug 26, 2016 02:56 PM
Varooom
Nov 24, 2015 06:06 AM
GaugeMods
Apr 20, 2013 02:24 PM
Keithhu
Jul 18, 2012 07:58 AM
