my 09 ultra pops during decel quick question i checked closed throttle position with my lap top thats ok it was 0% then i wanted to add 10"s in the fuel map colum how do i do this to the left of the screen there is a table one and table two for both cyclinders.i click on table one then add 10'S in the 0 colum from 1750 to 5000 do thesame for table two then what do i do
Kind of related but won't help you any with your question...I don't get anything in the middle of my screen...it's just blank. Everything else seems fine. How'd you get the table to come up? My PCV came loaded with a map so I didn't download anything. Did the table come up when you turned it on or did you have to click on something?
Thanks for any help and sorry for jumping in like this...
first when you down loaded the software you did down load the power com v verson ok then connect cable turn run switch on start bike right side of screen shows rpm throttle position ect. on the left side hit button open map file
Yes, you will add 10's to both fuel table 1 and 2 in the 0% column from 1750-5000 RPM's and when finished hit send map which will send the map to the PC-V unit.
The main center screen remains blank in the PC-V software until you pick a table on the the left which gives you the options fuel 1&2, igntion, and if you have AT enabled an AFR table as well
jamie so i will put 10's in the o colums from 1750 to 5000 thats 14 boxes for each cylinder then press send map thanks bike is running real good just some decel popping i needed to get straighten out thanks for the quick respones FUEL MOTO ROCKS !!!!!!!
i checked all muffler clamps everything seems tight no Appearent leaks.the bike didnt pop until i installed the pcv bike runs grate just alittle decel pop hope when i put 10's in the 0% colums all will be well thanks
