Red line increase
Old Aug 17, 2009 | 10:06 AM
Buddy04284's Avatar
Buddy04284
Yes I understand about over revving and actually losing power at a higher RPM. My 07 night Train with a stage 1 kit and D&D fat cat 2 into 1 pipe pulled all the way on the dyno to 6100 rpm. my new 09 bagger seems to poop out just after 5600 rpm
Old Aug 17, 2009 | 10:41 AM
timvan's Avatar
timvan
Twin cam A vs B...Touring vs softail... TBW vs cable
this can go on and on
Old Aug 17, 2009 | 11:09 AM
iclick's Avatar
iclick
If you don't plan on doing anything else to the bike (i.e. tuner and AC), the Stage 1 download would be the only way to increase the limiter. OTOH, like some have already said, without opening up the intake I don't think the revs will be there in a practical sense that would provide better performance. The HP curve for a stock '09 setup starts dropping off at about 5000 RPM. Based on a dyno chart I've seen it drops about 5HP from 5000rpm to the stock redline (~5600 IIRC).
If you're going to spend $125-150 for the download you should also install the SE AC, which will help performance noticeably and should allow the engine to breath freer and open-up the top-end more.
awkoch
May 8, 2014 02:19 PM
Zakk13
Aug 11, 2011 09:44 AM
Dagerazod
Dec 25, 2008 08:07 PM
fishspi
Exhaust System Topics
May 16, 2008 09:58 AM
BLAZE
Jan 3, 2006 01:29 AM
