Replacing shifter linkage
Old Aug 16, 2009 | 01:41 PM
1HarleyGuy1's Avatar
1HarleyGuy1
Default Replacing shifter linkage
Got home from a ride yesterday and started doing my after-ride clean of the bike. Was just starting to buff up the inner and outer primary covers and noticed that me shifter linkage had come off on the front end!! I have checked the forums and decided on going to the heim joint replacement type but I couldn't find anything as to how the swap is done.
Anyone help out with some instructions or point me in the right direction? Is it a hard change or fairly straight forward.
Thanks
1HarleyGuy1
Old Aug 16, 2009 | 01:50 PM
dawg's Avatar
dawg
Loosen jam nut and unscrew crap linkage end, install heim joint and tighten jam nut. Put bolts through to the mounts and tighten. I sent you a PM also
Old Aug 16, 2009 | 01:58 PM
max56's Avatar
max56
Veteran: Coast Guard
It's all pretty self explanatory. Even a caveman could do it. Follow dawgs instructions and you'll have no problem. I used a little blue Loctite when I did mine. I use blue Loctite on just about everything, though.
Old Aug 16, 2009 | 02:02 PM
1HarleyGuy1
Thanks guys. I'm going to change from the stock linkage to a new one. The stock one seems to have a "ball" type piece that come out towards to side of the bike. I take it that just comes off with the screw on the motor side of the linkage?
Old Aug 16, 2009 | 02:06 PM
nvsteve's Avatar
nvsteve
Do a search on ebay for harley shift linkage. Wording might be a bit different.
There's a guy that sells the heims for about $20. There's also some different rods for reasonable prices if you want to change.
Old Aug 16, 2009 | 02:21 PM
dirtdobber's Avatar
dirtdobber
I got a kuryakyn with heim joints that is chrome for $39
The jam nuts were somewhat a headache but it was still rather easy to do.
In God we trust
dd
DGRF250
2014-2024 Touring Models
15
Apr 28, 2014 11:58 AM
mainshaft
Jun 25, 2012 02:05 PM
jmbaker3
Feb 20, 2011 04:38 PM
fatboy5150
Jan 28, 2008 03:51 PM
dadofsix
May 2, 2007 07:36 PM
