I hate leaks and rattles. For the past few months my shifting linkage (heel and toe) have been bugging the chit out of me with the noise while rolling down the road, the shift rod is very loose in the inner primary housing. I was out Saturday and decided to stop at Lowe's, I found white nylon washers 1-1/4 X .516 X 1/16 they come in a package of 4 for about $0.92. I took off both heel and toe shifters, drilled a 3/4 inch hole in the center of one of the nylon washers slid it on the shifter shaft, reinstalled the short black rubber bushing and the shifters. No more rattle. I'm sure there are other ways to go about fixing this but for about $0.22 and 10 minutes worth of work that pesky rattle is gone.
I have the same issue and it drives me nuts - I went ahead and did the drill, tap and zerk fitting so I can easily grease the shift shaft, but I am also going to do your your fix as well. Thanks for the tip!
Thanks for the tip. You could also replace the bushings, which I guess are probably worn, which is why you have a rattle. My ole lady had a grease nipple from new, so I have always been able to lubricate it, but it getting sloppy now. Greasing that linkage improves changes, makes them smoother, so it is well worth while.
I tried the washer trick, as well as using some old wheel-bearing spacers I had lying around, and it worked for a while but the rattle kept coming back. On a friend's recommendation I bought a Softbrake Extended Spring-Loaded Spacer (#SB-ESS) for $22 shipped. That got rid of the rattle and most of the shaking in the shift assembly, and I don't see it coming back since the spring effects constant light pressure on the shaft and wear shouldn't be a factor. BTW, the above is for a toe-only shifter (heel portion removed), but they also have one for the heel-toe shifter (#SB-SLS, $19 shipped).
SB-ESS:
SB-SLS:
You can lube the shaft on newer bikes by just detaching the inner lever on the shaft and sliding it out. I've thought about drilling a hole and tapping some threads to add a grease fitting, but haven't gotten around to it (i.e., lazy).
Yes, but it's like $80 and accomplishes the exact same thing as my .99 zerk fitting Their greasable shaft just has the nipple on the end of the shaft with holes in the shaft that allow grease to get between the shaft and bushings. Same end result. I guess if you don't feel ike drilling and tapping the inner primary for the zerk, the Pingel solution is good.
I couldn't see any way to replace the bushings in my '07. It would be nice to have easily replaceable bushings because that's really what the problem is in the first place: the bushings have worn and allow the shaft to rattle. At least with a grease nipple, I will be more likely to grease it because it's easier than pulling and greasing the shaft. Not that it's hard. it's just that laziness comes into play
Your solution is the same as mine. However, there are some that do not have the mechanical apptitude and would instead take it to a dealer. Dealer cost to trouble shoot and grease the shift shaft, $200.00, the screwing they take...priceless!
Good one Yeah, some do not take lightly to drilling holes in their new bikes...the wife about had a fit after I brought mine home and week or so later had to drill out a stuck derby cover screw. "WTF are you doing?!"...
