09 street glide fairing removal?
Old Aug 19, 2009 | 11:52 AM
frozensoul's Avatar
frozensoul
Default 09 street glide fairing removal?
got a fuel light burnt out i think, would rather do it myself than take to stealer and i should have the weekend off so i would like to do it then. does any one know what all has to come off to remove the fairing as far as screws and trim light ring? i would think it wouldnt that hard i just havent done it before.
Old Aug 19, 2009 | 11:59 AM
Scout's Avatar
Scout
remove the three screws holding the screen in place,pull the screen slightly forward,and then up to remove. Then the two screws on the sides of the inside fairing, and two on the steel housing under the inside fairing. Pull the outer off slow, and disconect the plug on the back of the headlight. It's a very simple job. If you have any doubts, but the manual and it shows all.
Old Aug 19, 2009 | 12:13 PM
frozensoul's Avatar
frozensoul
thanks, and a manual is next thing on list since i do like to do as much of the work on my bike as long as i feel i can do it without screwing something up. thanks again.
Old Aug 19, 2009 | 12:17 PM
mayor's Avatar
mayor
I thinking about where my fuel light is.
Isn't it inside the speedo face??
If it is, just pulling the fairing is not going to get you anywhere near the inside of the speedo.
They are pretty much sealed up with a wiring plug on the back.
mayor
Old Aug 19, 2009 | 12:22 PM
Scout's Avatar
Scout
There's a plastic row with pullout lights that you access from behind the fairing. Also check the black connector box that has 4 black ground wires, and a few others that's resting above the stereo. If it's got crap in it, you have to clean and grease the connections. Might as well do it while you're there. Mine was corroded last week and the ground wire melted on my headlight connector because it was searching for ground.
Old Aug 19, 2009 | 12:29 PM
Primo's Avatar
Primo
4 things:
#1 Before doing anythng cover your front fender with a a towel or better yet a heavy blanket or comforter in case the outer fairing some how falls.
#2 Have a safe place to lay your outer fairing down on where it won't get scratched or fall. Have the space ready before you even remove one screw. Don't ask me how I know. :-}
#3 put the middle screw back in after removing the windshield while you remove the other 4 lower ones. This way the outer fairing cannot fall accidently.
#4 Check the connector before tearing into anything. Might just be a loose plug causing the lack of light.
Old Aug 19, 2009 | 12:30 PM
UltraTheo's Avatar
UltraTheo
Wouldn't this be warranty work? If it's the fuel light, that is in the speedo, so that will have to be replaced. I say take it to the dealer and let them fix it on their dime.
Old Aug 19, 2009 | 12:36 PM
myred55's Avatar
myred55
I don't believe bulbs are under warranty, but then again I may be wrong.
Old Aug 19, 2009 | 12:41 PM
Scout's Avatar
Scout
Primo's rules are great, just one more. When reasembling, do not over tighten the screws, or you'll just end up breaking the brass gromet away from it's plastic holder in the fairing.
Old Aug 19, 2009 | 12:50 PM
Geoff's Avatar
Geoff
Use the Search tool and look for "Fairing Removal". I recall seeing a nice procedure with photos. It's actually pretty easy. I removed my fairing this spring to install Hog Tune speakers.
There's good advice in this thread. Cover your fender and tank any time you work above these parts....and don't overtighten the screws that secure the fairing.
