Need Help With Power commander V
I just put a powercommander 5 on my 2009 Ultra Classic.
I screwed up and reset the throttle position sensor on the PC5.
I then read you have to do this on a dyno on the fly by wire system. So I am upable to set the high position with a dyno. This is because you need to run it a full throttle long enough to set the high position. I have enter some numbers on the TPS screen that are closer but I want to put it back to the default.
Does anyone know the default TPS numbers or how to reset the unit? I can call the power commander folks on Monday but thought I would try here on the weekend.
I don't know the details, but there is a lot of help at these postings:
https://www.hdforums.com/forum/touri...e-info-17.html
same thing happened to me https://www.hdforums.com/forum/touri...g-right-5.html
