I am considering ordering a King Tour Pak for my FLHX. Does the tour pak # 53270-08CPC come with the back rest pad, and if so does it have the FLHX stitch pattern?
I put the king tour-pak on my FLHX, it's Ala-carte for ordering the parts.
You will need to order
-King Tour-Pak
-Back rest pad in the style of your choice
-Detachable Tour-Pak rack (solo or two up)
-Locking hardware kit (use vin number to match ignition key)
-4 point docking kit for bike
-Antenna relocation kit
You might also want to order the upgraded hinges and LED light kit for the tour-pak.
It does NOT come with the Tour Pak. It is listed seperately because there are several different versions for the Ultra and the Classic and the Streetglide. You also have to order the lock set seperately.
Is there any difference between the king tour pack and a tour pack? I see different names listed on ebay. Is the king tour pack bigger than the tour pack?
For the question, no, it's only for the tour pack. Backrest, mounts, locks are additional.
