Saw this as an inexpensive way to get rid of the crossover pipe. It looks like I would reuse my stock heat shields too.
Anyone that is using this or a similar setup to the stock system, what's your opinion of the sound, what mufflers are you using stock with/without baffles or slipons?
I used them for a couple of years on my original pipes, plus Harley fishtails. You're right about using the original heatshields. You get the same sound out of both mufflers, which is very noticeable at first, but great! I never noticed before that they were not the same with the original pipes.
When I fitted my S&S motor I used a new set of Samson true dual pipes, with S&S oval mufflers. Or to put it another way, I liked the true duals so much, thanks to Fullsac, I fitted new pipes with my new motor.
I am using the Fulsac on my left pipe. Because I bought a set of Samson true duals and the Left pipe did not fit. So Samson said "tough you own em". I had to go with Fulsac on the left pipe. Stock heat shield works there.
I like it. Works well. Also I am using the B&E Mufflers (2") for the exhaust. http://www.superflowmufflers.com/products.htm
Everyone I have ridden with says they sound awesome.
I have used the fullsac conversion for along time and i love the sound.....you can put any slip on you want.....baffles.....i dont use them.....i did have to put torque cones in the head pipes to help with back pressure....they sound awesome.....
I use them along with a set of CVO touring mufflers with the Full sac 2" baffles.
It improved the sound immensely. I won't go back to stock......unless I trade up to another bike!
