Neck pain
Old Aug 28, 2009 | 06:59 PM
dawg's Avatar
dawg
Originally Posted by teqsand
What else did you have to buy and basically what did the switch cost you?
Thanks
38649-08 clutch cable for $34 and a tranny side cover for a few bucks and exhaust gaskets because you have to drop the exhaust to get to the tranny side cover. The bars are about $70. All in all it will be about $150 for you in parts.
Old Aug 28, 2009 | 08:14 PM
gmc's Avatar
gmc
So with 07's and prior will we need longer throtle cables and do wires need extending?
Old Aug 28, 2009 | 08:17 PM
dawg's Avatar
dawg
You can get by without throttle cables, but it's tight. When I had the bars on my 04 I ended up changing out the throttle/idle cables also. Wires do not need extending.
Old Aug 28, 2009 | 08:34 PM
teqsand's Avatar
teqsand
Big Kahuna HDF Member
So you didn;t have to extend any of the electrical? TBW?
Why did you have to replace the tranny side cover?
Did it put your hands in the airstream?
Old Aug 28, 2009 | 08:44 PM
BoomerBob's Avatar
BoomerBob
I'm having the +2 Sweepers put on right now. I've been running the standard Sweepers but they put me forward a little too much and I get the neck/shoulder pain with them. I'm only 5'10 though. Someone 6'2" might like them just fine.
Old Aug 28, 2009 | 09:00 PM
harley0711's Avatar
harley0711
My experence is YES - it does a little
In going to the khrome werks web page
the measurments of these bars are almost the same as the Wild1 575 but of course a lot cheaper...
Khrome werks
Wide 34.07
Endrise / tall 10.83
pull back 12.13
Wild1 575
wide 34.5
endrise/tall 10
pull back 13
great for taller people but us short guys - the width is often just a little too much...
Very hard for someone to shop bars without trying them out...
there could be a group of us and all sit on a bike, even if we are the same size - doesn't mean we will all like the same bar..
problem is, changing bars is $$$$$$$$$$$$$$$$$$$$$$$
Old Aug 28, 2009 | 09:04 PM
dawg's Avatar
dawg
ooops, I meant tranny side cover gasket (to change clutch cable). No electrical or TBW extension. I don't think my hands are in the airstream
Old Aug 28, 2009 | 09:33 PM
teqsand's Avatar
teqsand
The TBW is internal the bar correct? how was that to swap out?
Old Aug 28, 2009 | 09:41 PM
dawg's Avatar
dawg
Yes TBW is internal. It's a fairly easy job to swap out.
antman27
Jun 19, 2013 01:32 PM
parkashard
Sep 17, 2011 06:21 AM
medic3141
Jun 7, 2011 01:41 PM
fishercat
Nov 11, 2009 05:57 AM
digz`
Jun 17, 2009 10:16 PM
