Coughing during cold starts
Old Aug 28, 2009 | 12:48 PM
Dru's Avatar
Dru
Default Coughing during cold starts
During cold starts my engine starts to sputter like it is going to turn off. I give it some gas and after it warms up it stabilizes.
any thoughts?
Old Aug 28, 2009 | 01:17 PM
TheDon81's Avatar
TheDon81
Is the bike completely stock? if not have you retuned it? I suspect a tuning issue.
I had a similar problem (01 Injected), got worse when I installed K&N filter, got PCIII and got it Mapped been smooth ever since.
Old Aug 28, 2009 | 01:28 PM
Dru's Avatar
Dru
I have a Thundermax Auto Tuner, Arlen Ness Big Sucker II and Thunder Headers 2-1.
It have run fine up until a few months ago.
Old Aug 28, 2009 | 01:29 PM
Dru's Avatar
Dru
Oh and it's an 07 Streetglide
Old Aug 28, 2009 | 01:46 PM
fathertime's Avatar
fathertime
From: CHILLIWACK B.C CANADA: have a u.s shipping adress
my 08 does it and only has bub slipons.. no intake mods at all
Old Aug 28, 2009 | 01:58 PM
07RoadHawg's Avatar
07RoadHawg
Sounds like the problems Stro and I have been having with our '07 bikes with the T-max. I think I probably have an exhaust gasket leak because my fuel mileage has been tanking and I have the AFR tables leaned out pretty good. My plugs are pretty tan and they were quite a bit lighter before my cold start problems. Interestingly, my cold start issues only happen when the ambient air is above 80 or so. Cooler mornings the bike starts fine and never stumbles.
Old Aug 28, 2009 | 02:05 PM
stro1965's Avatar
stro1965
It's a mapping issue. You should contact Zippers. During the last firmware upgrade they apparently made some changes that they shouldn't have made that caused this problem. They fixed mine at Rapid City HD during Sturgis. It turned out to be a simple adjustment on the rpm vs engine temp page, it just needed some more room to "auto-tune" itself. I'm not at home right now but I can look and see exactly what they did once I am. What map do you run?
P.S. They told me they were going to post new maps with the correction on them, not sure if they have yet or not.
Old Aug 31, 2009 | 12:40 PM
stro1965's Avatar
stro1965
Oops...the corrections were actually made on the "AFR correction vs engine temp page". Sorry about that!
kingk9
Jun 24, 2014 10:50 AM
SD Night Train
Softail Parts
Jul 7, 2009 07:14 PM
Silvertip
Feb 3, 2008 09:21 AM
518Train
Exhaust System Topics
Aug 7, 2007 03:39 PM
DevotedDad
Jun 20, 2007 09:17 PM
