SE 255 cams , D&D Fat-Cat dyno results
Old Sep 3, 2009 | 11:18 PM
THABULL's Avatar
THABULL
Default SE 255 cams , D&D Fat-Cat dyno results
Stock 96cu. in. SE 255 Cams , D&D Fat-Fat 2 into 1 with a PCIII tuner! 83hp 98ft lbs of torque , this combo peaks at 2500rpm and pulls up to around 4000rpm! IMO not bad of a return on investment considering I got the Cat used at 1/3 of the new cost off the local craigslist!
Old Sep 4, 2009 | 02:28 AM
emwolb's Avatar
emwolb
so, what does the butt dyno tell you? impressed or not? surely that's a huge increase per dollar spent. lettuce know. that does look like a huge increase over stock.
Old Sep 4, 2009 | 09:14 AM
wldegl's Avatar
wldegl
did you have the heads worked at all?
Old Sep 4, 2009 | 01:42 PM
iclick's Avatar
iclick
Your numbers are about like I expect for a setup like yours, which is to say excellent. Could you post your dyno chart?
The 255's have a number of things going for them. For one, they are arguably the best low-end and midrange cams available for an otherwise stock TC96. Second, you can typically find these on Ebay for about $100 used, $150 new. IMO they are a great bang-for-the-buck upgrade for a heavy bagger if your priority is between 2000-4500 RPM's. Peak HP will increase some, but will peak at about 5K RPM. OTOH TQ is another story. It comes on strong from 2500-4500 and doesn't decrease in the extreme low-end. I don't know of any other aftermarket cams that will retain or increase the low-end with stock CR.
I did a write-up on my DIY cam job here.
Old Sep 4, 2009 | 01:45 PM
THABULL's Avatar
THABULL
Pulls like a freight train!
Old Sep 4, 2009 | 01:48 PM
PhilM's Avatar
PhilM
I have some 255's that I'll gladly take $125 (+shipping) for....
Afterall, "they are arguably the best low-end and midrange cams available for an otherwise stock TC96". Just see the post above... It's right there in print!
Old Sep 4, 2009 | 01:49 PM
THABULL's Avatar
THABULL
Didn't get no dyno sheet but I was in the dyno room for the entire tune! Tuner worked 4 hrs overtime up to 22:00 last night so we where both pretty tired! Zach Johnson son of Kendall Johnson did the tune! http://kendalljohnsoncustoms.com/
Old Sep 4, 2009 | 01:53 PM
sandnessmj's Avatar
sandnessmj
How much did that work cost you? I live just north of Charlotte, and have heard good things about the Kendall Johnson shop.
Old Sep 4, 2009 | 06:33 PM
iclick's Avatar
iclick
Are you implying through irony they are not? If so, what is better along those parameters?
Old Sep 4, 2009 | 07:58 PM
PhilM's Avatar
PhilM
Perhaps: Andrews 26H or 37H, HQ 500 or 525, R&R 525, TMan 525, WildThings 1 or 2, & Woods 6-6 for starters. I'm sure I've overlooked several, but that's a start.
If you're happy, enjoy your ride, but a claim that it's "the best low~mid range cam available" is short sighted & mis-leading at best.
That said, different strokes..... not interested in arguing with you.
