Is it normal (moisture in gauge)
Old Jun 14, 2006 | 01:54 PM
jlacasci's Avatar
jlacasci
Default Is it normal (moisture in gauge)
Hey folks,
I have an 05 Ultra, every now and again I notice a bit of moisture in the fuel gauge. It eventually dries out and it's working just fine.
Is this normal?
BTW, yes I do wash it relatively often, like once a week. No I don't flood the gauges head on with water, but I do "gently" spray them lightly from the top as if rain was falling, wipe them down and rinse the same way.
Joe
Old Jun 14, 2006 | 02:04 PM
QT Hush's Avatar
QT Hush
Default RE: Is it normal (moisture in gauge)
My 2001 Electra Glide Classic does the same thing.
Old Jun 14, 2006 | 02:17 PM
King Rider's Avatar
King Rider
I have a O6 RKC and it always seems to get moisture in the gas gauge after I wash it. It's always worked so I think it's ok. I am thinking of changing to the flush mount Kuryakyn LED gas/voltage cap. Looks real nice.
Old Jun 14, 2006 | 02:18 PM
Big Daddy K's Avatar
Big Daddy K
I get the same thing...& I don't wash my bike alot. I believe it has to do with the change in temperature & condensation building up when taking it out of the garage.
Old Jun 14, 2006 | 02:21 PM
sleepneagle's Avatar
sleepneagle
Well come to the world of FLHTC. Only remedy is small hole drilled in bottom of gauge housing. it will still fog, but you have a vent so the heat from the light will vaporize the moisture quicker.
Old Jun 14, 2006 | 03:32 PM
PipeDADDY's Avatar
PipeDADDY
FLTRI does after a wash normally it was the air guage. it dried out too. after a wash or a rain.
Old Jun 14, 2006 | 05:20 PM
Prw3's Avatar
Prw3
Thats pretty standard for HD gauges, even my 1999 RK would moisure up on wet days or after cold doys. Keep in mind that HD does not make and assemble their own gauges so who knows where and how moist the assembly line is where and from whom they assemble them or how sealed.
Old Jun 14, 2006 | 05:52 PM
no911forme's Avatar
no911forme
6th Gear
My 05 Ultra has the same problem, and I have never washed my bike or rode in the rain.
Old Jun 14, 2006 | 06:13 PM
Mr Wonderful's Avatar
Mr Wonderful
ORIGINAL: jlacasci
Hey folks,
Is this normal?
Joe
I quizzed a factory rep about the gauge problem. He said that they are aware of the condensation and the only true fix is to install liquid-filled gauges, but them being so small in diameter makes them cost prohibitive for a production basis. Seems we'll be living with this issue for quite some time to come.
Old Jun 14, 2006 | 06:45 PM
solorider's Avatar
solorider
ORIGINAL: jlacasci
Is this normal?
Joe
Unfortunately, yes it is. [:@]
This is a very common problem and has been discussed here many times. A search of the site may find you more information on it.
