Temperature Alert Setting
Old Sep 10, 2009 | 07:49 PM
Mark MPDC's Avatar
Mark MPDC
Default Temperature Alert Setting
I want to ask most of you that when you get stuck in traffic do you know at what temperature does your engine light start to blink for your engine running hot?
Old Sep 10, 2009 | 07:57 PM
nocarb's Avatar
nocarb
Originally Posted by Mark MPDC
I want to ask most of wen you get stuck in traffic do you know at what temperature does your engine light start to blink for your engine running hot?
Never heard of engine light coming on for high temperature.
Where did you here this?
Old Sep 10, 2009 | 08:10 PM
1flhtk4me's Avatar
1flhtk4me
One time stuck in Vegas traffic,my engine started run on one cyl.
I just started to split lanes to get back to the hotel.
The answer to your question is,HOT!
Old Sep 10, 2009 | 08:14 PM
clutchglass's Avatar
clutchglass
Here are some infra red picd I took of my 09 Ultra last weekend. I started it up...took a pic...then let it idle till the Engine Idle Temperature Management System kicked in.
-clutch-
Attached Thumbnails Temperature Alert Setting-ir_0971.jpg   Temperature Alert Setting-ir_0976.jpg   Temperature Alert Setting-ir_0982.jpg   Temperature Alert Setting-ir_0987.jpg
Old Sep 10, 2009 | 08:29 PM
Mark MPDC's Avatar
Mark MPDC
I know on my 04 road king when the temp is getting too hot the engine light starts to flash slowly then as it gets hotter and hotter it starts to speed up the flashing until it stays solid,so is this just afeature they have done on 04's?
Old Sep 10, 2009 | 08:59 PM
stro1965's Avatar
stro1965
Hey Mark- it's a T-Max thing. And you can set it to throw a CEL at whatever head temperature you'd like (mine is set for 325).
Old Sep 11, 2009 | 12:17 AM
wingman05's Avatar
wingman05
I have a set of Dakota Digital Gauges. The Oil Temp gauge can be set for 232 or 278 degrees. When your oil temp exceeds the selected setting, the display flashes until the oil cools below the set temperature.
Old Sep 11, 2009 | 01:51 AM
Mark MPDC's Avatar
Mark MPDC
I think you on the road king for 04 the sensor for that engine light is for the cylinder heads.I have no oil cooler yet on my bike nor do i have one of those fans that sit in place of the horn.My bike gets hot very quickly if i'm sitting in traffic for 20 mintutes after already been riding hard and now you come to a dead stop surrounded by cars and all that heat.
jbnl163
Apr 30, 2013 09:57 AM
Hogster 1
Jan 24, 2013 06:23 AM
jbyun
Apr 4, 2010 05:44 PM
ardbark
Oct 4, 2008 03:00 PM
cglofland
Apr 30, 2008 07:26 PM
