i hate my 2010 RG custom!
I spent 2 days doing experiments on my RKC because i was having terrible buffeting issues. I even ordered the replacement windshield from Clearview w/ recurve, and was shocked when I put it on, and the buffeting got worse! I was so frustrated, that I grabbed the shield on the corners with my hands, and lo and behold, the buffeting stopped! WTF?!? That started me moving my hands into different positions, and then making a cutout of my shield that was the same width, and then a little wider. I moved it around until I found out what the issue was... the air coming straight past / over the corners of the shield were getting churned by the air rising off the shield itself, and pummeling my head. That, combined with the negative air pressure behind the shield (vacuum) only needed one thing... a higher shield with a more squared off corner section, which I have had Clearview make for me - it is shipping tomorrow, fingers are crossed that this is it.
The RKC doesn't have the same issue that the RG does, because it isn't a wing-like shape... it is a door / brick being pushed into the wind. At almost 6'2'', I am learning that taller riders have a much harder time with this stuff than do shorter riders. Just hang in there, and you can work it out! Good luck, and I will post what happens when my CV comes in...
http://www.nationalcycle.com/catalog...ream_FLH.shtml
I forgot what those vortices coming off the corners of the windshield were called, and then I remembered this site. I had one of their windshields on my Honda ST1300, and it was incredible. It might not be the best looking, but it sure does work as advertised....
http://www.allamericanh-d.com/new_ve...ory.asp?page=3
make the deal and jump on a plane and ride that sucker back by way of a non interstate route and you'll be all ready for your 1K miler when you get home. I did 13 hours to Nashville to get my bike last Sept. I'll even pick you up from the airport in DC or Baltimore.
