Handle Bar Adjustment Question
Let me guess you didn't have a manual?
So do you also keep tightening a bolt when you realize that is is probably crossthreaded? No of course not because that is not how to properly do it. You may have not hurt anything doing that but it isn't worth it on a $20K bike to half *ss it. You could have pinched brake lines rubbed down the knurls so when you grab a handful of front brake and don't stop you will have only yourself and your buddy to thank.
Doh!
When the manual is read at the part on HOW to install the handle bars - it will give a sequence that is NOT mentioned in any post above - according to the book, there is a special way to install the four bolts - It is super easy to cross thread them... I have done this several times and the Radio MUST be removed to do the by the book - lots of people short cut the process and they may get away with it.. for me, I will follow the book -
everytime I have done this... I put the clamp (BTW - use a Single clamp always) on and start the bolts by hand too see how far I can get them it... then install the bars and start all bolts by hand,,,IF I can not get them to start like my 'test' I stop and find out why - I a person just grabs a wrench - it will cross something.
2004 manual - page 2-98
5-a
Tighten front screws until upper and lower handle bar clamps make contact
b. Tighten rear screws to 12-16 ft pounds
c. stighten front screws to 12-16 ft pounds
Note: a slight gap will exist betwen the upper and lower clamp at the rear of the handlebars after tightening..
No where does it say to use either blue or red loctite... I have read on the forum in several posts where people say to use either blue or even red loctite... good luck
book
Now, go buy the book...
5-a
book
Worst advice I have ever read on this forum.
I know you said to give you a break on getting the manual, but it will pay for itself on this job alone. It's a relatively easy process if you have the walk through. The manual says to get to the adjustment from the inside fairing, partially disassembling the ignition switch then removing the fairing cap. Once the fairing cap is off, you can access and loosen the the rear screws on the upper handlebar clamp. Adjust as necessary. Again, the manual makes it much easier to understand, but it's covered in three seperate sections. Hope this helped.
Good advice. And I would mark the original position of the bars before adjusting them. I was glad I did. By the way I have found that the higher I have my hands the more likely I am to get neck/shoulder pain.
My dealer adjusted mine this way, and I have done it myself. Watch how you take the ing. switch out so you put it back right. There is a little more of a trick to removing the ign switch than is described here, but it really is easy if you know how. The best advice I can give you is go by a dealer and ask the service dept if they will show you how to take out the ignition switch. It only takes a second. If you do a search here and happen to use the correct key words, you will find many posts that start out. "Help, I took my ignition switch out and can't get it back in." Also, if you don't have the ball end allen wrenches, get some. You can't really get to those bolts straight on. Lots of things to scratch close to those bolts so be careful.
