No Start
Old Sep 16, 2009 | 09:38 PM
Indianspringsaz's Avatar
Indianspringsaz
Default No Start
Bike wont start in gear. Does nothing, like a neutral safety switch. I have to put it in Neutral. Is this normal on a 07 Road King?
Old Sep 16, 2009 | 09:50 PM
imrotton2's Avatar
imrotton2
do you have compression releases???one of my bikes is sometimes hard to crank in gear with clutch in... i think the clutches work better when things are spinning and getting wet with the oil.... i'm usually startn in neutral
dawg's Avatar
dawg
You pulling in the clutch lever? There is a switch in the perch that won't allow you to start it without the lever pulled in. If you are pulling in the lever, was any work done that could have fugged up the lever switch recently?
Old Sep 16, 2009 | 10:01 PM
Indianspringsaz
Well I did put Ape's on it. It will start fine without the clutch pulled in in neutral, but it does nothing when in gear with the clutch pulled in. Like a neutral safety switch on a car.
Old Sep 16, 2009 | 10:06 PM
dawg's Avatar
dawg
The safety switch is like a safety switch on a car. Might have fugged up the switch putting it back together.
Old Sep 16, 2009 | 10:11 PM
Indianspringsaz
OK, I will look into it.
rogersachs
Feb 20, 2014 12:17 PM
Ernst
Feb 14, 2013 08:38 AM
VaThumper
Jan 27, 2011 11:08 AM
Pony Soldier
General Topics/Tech Tips
Sep 10, 2010 12:46 PM
hockeypuck
Aug 19, 2009 02:44 PM
