Starting problem
Old Jul 1, 2010 | 12:05 PM
Pony Soldier's Avatar
Pony Soldier
Default Starting problem
My 07 ULTRA will not start in gear with clutch pulled . Srarts fine in neutral. Is there a sensor,a switch,or a fuse that could be bad ?
Old Sep 10, 2010 | 12:42 PM
Nute's Avatar
Nute
All the above. Most likely has something to with clutch over-ride switch located on the left handle grip and activated when you pull in the clutch. There is an interlock that over-rides the safety so you can't accidently start bike in gear unless clutch is pulled in. Some people disconnect this option so bike can only be started in neutral. (another switch involved here)
Old Sep 10, 2010 | 12:46 PM
Faast Ed's Avatar
Faast Ed
If you ever replaced the stock lever for a chrome one, you might have a lever that no longer engages the switch.
Max Headflow
Milwaukee Eight (M8)
38
Nov 10, 2020 08:17 AM
VaThumper
Jan 27, 2011 11:08 AM
amontances
Oct 11, 2010 08:08 PM
Indianspringsaz
Sep 16, 2009 10:11 PM
CLL375
Aug 14, 2006 04:25 PM
