engine build question
Those numbers look about right from the research I've done. I did a low budget cam swap this spring and when I was searching on here for info I discovered that you really dont gain alot by going to 103 vs 96 with the 255 cams. You need some some head work and increased CR and different cams to get over the 100 HP mark. As a reference, my 96 with 255's makes 78hp/98tq with a similar exhaust/intake as you. For the money I spent, I am very happy with the results.
The Andrews 54 cam choice is a good one. I went with it on my builders advice and am happy I did. The Torque is now above 110ft/lbs from 2500 rpm to 5000rpm. My bike pulls like a train. all at 9.8 compression.
If your on a tight budget, get the 107 pistons and the Andrews 54's. See if you cant sell some stuff around the house and get some head work.
Chris
Chris
Good chance you will reach your goal without porting the heads, but for me it would be hard to assemble without doing something with them, even if it's a minimal clean-up & cc.
If you do decide to swap the pistons, you might as well go 103". Won't cost much more at all and you have to do the labor anyway.
10:1 is a safe choice with that cam. It is very well mannered. I run mine at 10.4:1 and it behaves well. The only ping I ever got was in the mountains near Sturgis when it was hot and running on the crappy fuel thay have there. ON decent fuel this thing behaves like a champ! (but I am pushing the limit). 10 - 10.2:1 would put you in a comfortable range for that cam. It is quiete and very well mannered. Lots of low end grunt and still some on the top to play with.
Back when they first were coming out with the 54's, I had chatted a lot with a guy who had influence on the creation of that cam. (Jewelen Dewey). He was doing a lot of reputable heads at the time (I had run some of his heads in the past).
Dewey was fortunate enough to get some prototypes to test, before that cam hit the market. He was testing them in stock 96 inchers as a bolt in "cam only" scenario and was having great results. My original plan was cam only!
I wanted to reuse my stock pushrods, so I had the gas tank and rockers off. Figured I might as well throw the thinner head gaskets in. With the heads off I figured it would be hard to put them back on without some headwork. Then I look at the jugs and think "there are no more bolts involved to pull these jugs for 103". LOL
"One-more-itus" got the best of me!!!!!
Many on another board followed my build, for I was truly a guinia pig. I was the first 103 with that cam at the time and many had thought the duration would be too short for a 103. They called it a "baby cam".
Since then it has become more popular and some call it the "underated cam". Best mannered cam I have ever run. Performs in all ranges and still has some ***** at the top. Valvetrain runs quiet as well!
Absolutely no regrets.
I am very familiar with a few cams, but not an expert on all cams (just to set the record straight).
Nice, you still running the stock TB? Also which baffle are you running on the fatcat. Im running the standard baffle on my 98" build and I got a dip right in the same area.
