Its actually for my ultra which has the street glide rear on it...
looking fo the mount to use a cb antenna on the right side inbetween the saddlebag and fender
The am/fm part # is 76228-09 as shown on page 198 of the '09 parts manual... I can not locate a cb mount part # anywhere in the manual..
Tim, if you PM Dawg or go by the HD store a kit breakdown will show the part nos. of what's included. That should give you part no. for the bracket. The '08 and earlier kits included a mount for the antenna mast with knurled rings for tuning the antenna with an SWR meter. Don't know if that's the case with the newer kit for '09 and newer bikes.
HD does not have a single part # listed for this item... I can purchase the whole kit at $90...
Cut n weld here I come
Well, in the matter of a few hours you went from not knowing they had a kit that would do what you want, to knowing they have a kit that does what you want; to knowing that the bracket you want from the kit is not a separate sale item, but you could buy the kit and return it after you have used the bracket in the kit as a pattern to fab your own bracket.
I guess you enjoy cutting and welding; I can't do either, but I try to be sensibly thrifty. Killer Creek HD has one in stock.
Good luck with your project.
The issue is I have a street glide fender on a ultra... I have the detachable TP kit for a ultra (which as you know comes with all the "cables" and mounts) so I dont need to waste money on additional cables or mounts now that I made them in under 30 minutes with a cutoff wheel and welder.... and Its the way I want it. Wasnt much else going on today with this great weather were having anyways!
