What tie downs do you recommend
Old Sep 21, 2009 | 02:15 PM
Ozoneman's Avatar
Ozoneman
Default What tie downs do you recommend
I need to get some tie downs for hauling my bike. I plan to use a Nomanco motorcycle trailer. Anyone have any recommendations?
Old Sep 21, 2009 | 02:21 PM
Iamopie2's Avatar
Iamopie2
I went and got the HD soft ones. They have been used many times and work great for me. The best thing is that they have a built in loop in the tie down so the only thing on the metal is the soft material and not a metal hook.
Im sure there are lots of others, but I like the HD ones
Old Sep 21, 2009 | 02:31 PM
Ozoneman's Avatar
Ozoneman
What about straps? How do you just use the soft loops? Don't you need ratchet straps too?
Old Sep 21, 2009 | 02:35 PM
roadkinglobo's Avatar
roadkinglobo
Cool
HD HOG ties work pretty well. Never let me down in 4 yrs. trailering in bad weather.
Old Sep 21, 2009 | 02:39 PM
Iamopie2's Avatar
Iamopie2
They have the friction buckles on them. So all you do is pull them and they hold until you release it.
They are these http://www.harley-davidson.com/gma/g...bmLocale=en_US
Old Sep 21, 2009 | 02:44 PM
petemac's Avatar
petemac
I think the Powertye's are the best out there. I have the 2" Big Daddy's and use 6 of them.
http://www.powertye.com/product_info...products_id=98
Old Sep 21, 2009 | 02:52 PM
Ozoneman's Avatar
Ozoneman
Do you think the 1 inch would be good enough? How do you run the Powertye's?
Old Sep 21, 2009 | 02:55 PM
petemac's Avatar
petemac
Never used the 1", but I'm sure they'd be fine. It's very good quality. You attach them just like any other tie down, I just prefer to use 6 straps for added security.
Old Sep 21, 2009 | 03:01 PM
HarleyDavidB1967's Avatar
HarleyDavidB1967
Aside from a good tie down, a trick that works for me is putting a small scissor jack under the frame once the bike is tied. This eliminates any bounce, also you don't have to pull the suspension down so hard.
Old Sep 21, 2009 | 03:52 PM
Sharknose's Avatar
Sharknose
I use four of the 1" wide ratchet-type tiedowns. I think the ones in my garage are rated around 1000 pounds each. The slip-fit ones are better suited to lighter bikes.
Resist the temptation to go with the wider straps with the ratchet you can put your hand through. You can actually put too much stress on your bike with the big ones.
If you like the soft loops (and I do) it makes hooking the hook to your bike a lot simpler.
