Solo Disc front wheel
Old Jun 20, 2006 | 01:00 PM
Cayjay1's Avatar
Cayjay1
Stage I
Default Solo Disc front wheel
I want to run a solo disc on my front wheel (replicating a "58 Duo Glide look). The question is can I run a Softail 16" wheel and change out the braeings, or do I have to run a RK wheel? If I run the RK wheel, does anyone know how I can get a hubcap to fit with the 1" axle and specer? Thanks
Old Jun 20, 2006 | 01:03 PM
lil_gmac2's Avatar
lil_gmac2
Default RE: Solo Disc front wheel
IMHO baggers need both disc brakes to have good stopping power unless it's a show bike.
Old Jun 20, 2006 | 01:10 PM
ricoman's Avatar
ricoman
you would need to change the forks to one for a single disc or the second caliper mount would be empty and look kinda odd.
Old Jun 20, 2006 | 10:21 PM
DI75's Avatar
DI75
Switched my 06 street glide. Looks awesome. Suggest you switch to a 6 piston single caliper.
Old Jun 21, 2006 | 05:02 AM
ZookHD's Avatar
ZookHD
Went to a 13" single disk with 6-piston caliper on my Electra glide turned Road Glide. Youll need to change the master cylinder to an 11/16" bore and replace or grind down your fork tube. Good luck.
SK_Vega
Jan 16, 2020 12:15 PM
jqb12
Wheels/Tires
Mar 28, 2017 04:42 PM
roadkingbigjoe
May 14, 2014 11:43 AM
kenlani
Sep 12, 2011 11:26 PM
kingofsand21
Feb 10, 2010 10:41 PM
