reach seat question
Old Sep 25, 2009 | 07:15 AM
locodude's Avatar
locodude
Default reach seat question
I'm a little inseam challenged (30 in) and am less than flatfooted at stops on my 09 ultra, looking at a reach seat and it sounds like it will solve that but I don't really need to be moved forward, I'm very comfortable with the stock seat position in that regard. so my question is how far forward does the reach push you? or would just lowering the suspension work out better. I only got about 350 to spend and I think lowering the suspension costs considerably more than that.
Old Sep 25, 2009 | 07:28 AM
FLHTCU Owner's Avatar
FLHTCU Owner
A buddy of mine has the Reach and has not mentioned anything about moving him forward, just lower about 1" or so. Also if you haven't already done so, consider the riding boots with the thick soles.
Old Sep 25, 2009 | 07:35 AM
soos's Avatar
soos
I found the reach seat to be very uncomfortable. It was on my scoot for less than 24 hours. I wear Chippewa Logger style boots with a high heel and thicker soles. My scoot is an '06 with a Sundowner seat.
Old Sep 25, 2009 | 07:43 AM
hawg20's Avatar
hawg20
I too have a 30" inseam. I had the dealer put a lowering kit. 1" and I wear Justin Roper boots, they have a good sized heel and are lined with gore-tex. Couldn't ask for a better riding boot. I am now just flat-footed. Not great but lots better than stock. I am using the Sundowner seat. It's more comfortable than the stock seat. Good Luck in your quest for comfort!!
Old Sep 25, 2009 | 08:07 AM
paguy's Avatar
paguy
As far as I know all reach seats bring you forward, around an inch. My inseam is 30" and shrinking. I have a Corbin solo reach seat and like it. Problem with lowering is loss of ground clearance.
Old Sep 25, 2009 | 08:39 AM
piasspj's Avatar
piasspj
I have a 30" inseam. Lowering blocks work for me on my '08 Ultra. The dealer installed them as part of the sale. Lowering blocks are the cheapest solution $25-$50. Replacing shocks can be done for about $100 if you look.
You also could have your seat modified or get an aftermarket seat.
Old Sep 25, 2009 | 09:05 AM
DrPlastic's Avatar
DrPlastic
30" inseam...damn I wish I had a 30" inseam!
You should feel blessed as I only have a 27" inseam! I have the Reach seat and I have also had the front and rear Profile suspension pieces installed at delivery. Along with my River road highway boots I am able to flatfoot with ease.
The Reach seat moves you fwd 2" and lower 1". It is a bit uncomfortable but I have grown used to it. I plan on installing 2" pull back bars and extenders for the boards to move them fwd 2" and out 1". Then I will be set!
Old Sep 27, 2009 | 09:16 PM
ucommbxny's Avatar
ucommbxny
had my seat customized (lowered and shaved sides), and good ridding boots problem solved
Old Sep 27, 2009 | 10:56 PM
jberg's Avatar
jberg
Reach seat is supposed to move you 1" closer and 1" lower. Also narrower at the front allowing your thighs to be closer together. I have a Reach seat but I'm using my original seat with Mean City Cycles modification. That, along with adding 1/2" to the soles of my boots, did the trick. Lowering should be a last resort.
Old Sep 28, 2009 | 03:31 PM
Super Mario's Avatar
Super Mario
I am inseam challenged, same as you. I tried the Reach seat but did not like the way it moved me forward. I have since sent my stock '08 Ultra seat to Mean City Cycles for rework and am thrilled with the results. I recommend giving those guys a call and you will have a stock looking seat that fits you perfectly, not to mention that out of that $350., you will have plenty of cash left over for more goodies!
