12 volt outlet
I put an in line connector in the nacelle so I can get rid of it when I ride without the windscreen (which is very rare indeed).
I started with a Kuryakyn power outlet and bar clamp...
I did not want a separate clamp for the RAM ball, so I made a quick bracket out of aluminum to attach the ball to. All-in-all it worked out great and looks pretty good.
I do like the Powerlet and it would have been a clean solution as well. They just seemed a little expensive for what you got, so I decided to see what I could do on my own. In the end, this was done for about half the price of a comparable powerlet, so I am pretty happy.
To wire, I ran from the power outlet into the nacelle and followed the main wiring harness to the battery. The Power Outlet comes with an in-line fuse and just wires to a constant power and a ground.
By mounting it in this location the wiring is completely hidden and very clean
Terry
