Engine just quits?
Old Oct 1, 2009 | 08:12 PM
stro1965's Avatar
stro1965
I use my kill switch religiously and it was my ignition switch that went south.
Old Oct 1, 2009 | 08:20 PM
Hx3's Avatar
Hx3
Another potential cause is the Engine Temp Sensor. Had a very similar problem that this has solved on my 03 UC. It only costs $37 and is located just behind the horn on the back of the front cylinder. Requires a 3/4" deep well socket to replace.
Old Oct 1, 2009 | 08:31 PM
dklanecky's Avatar
dklanecky
Casual water from rain, or a bike wash and easily get in the fuel adder connection with the ECM under the seat (PCV, Ect.) and cause an intermittent short. Dielctric grease is your friend!
Old Oct 1, 2009 | 09:04 PM
Getyurmotorunnin's Avatar
Getyurmotorunnin
Main CB in front of the Batt. Thats what was wrong with mine.
Old Oct 1, 2009 | 09:38 PM
kpb46's Avatar
kpb46
This is kind of a question to all and maybe an answer to the Problem. Do Harleys have bank angle sensors ( a switch that shuts the motor down if you drop the bike). I ask because when I owned a Goldwing I had the same problem...bike would quit and not restart until you turned the ignition off and on. Turned out to be a defective B/A sensor. Just a thought
Old Oct 1, 2009 | 09:42 PM
Sandy Mike's Avatar
Sandy Mike
Smile
Thanks all for your quick responses, nice to get some advice on the problem. From the descriptions others put I think my first step will be to clean the contacts on the kill switch, then try it for a while to see if the problem returns. Appreciate the assistance.
GA-Mtn-Rider
May 25, 2022 03:59 PM
98 Harley Dude
Sep 3, 2012 04:42 PM
markkoby
Feb 13, 2012 03:51 AM
dynamac
Nov 27, 2010 10:13 PM
rking2000
Jan 30, 2008 11:59 AM
