Laydown license bracket for tour pack detach kit
Old Oct 6, 2009 | 07:55 AM
WildThang's Avatar
WildThang
Originally Posted by frontiercat
My bike is an '09....
And a nice one at that!...thanks again for confirming the part numbers....
Old Oct 6, 2009 | 08:02 AM
frontiercat's Avatar
frontiercat
Back at ya. No problem man, ride safe!
Old Oct 6, 2009 | 01:44 PM
BoJunior's Avatar
BoJunior
I recently added the tour pack detach kit to my 09 FLHTC. Do you know if there is a license plate laydown bracket available that works with the detach setup?
I have 09 FLHTC also and would like to add the tour pack detach kit,is this a HD kit? What is the p/n. How much does it cost? Thanks for any help.
Old Oct 6, 2009 | 03:45 PM
WildThang's Avatar
WildThang
The HD part number is 53246-09A...$549 through HD...$462 through Zanotti
Old Oct 7, 2009 | 08:09 AM
BoJunior's Avatar
BoJunior
Thanks for the info I will be checking into this,did you put the kit on? By the way you bike looks bada$$ with the tour pack removed,that's the way i want mine to look when riding solo.Is that Zanotti HD in Butler.PA?. If you don't mind would you tell me what comes with the kit.
Old Oct 7, 2009 | 08:46 AM
cosshog's Avatar
cosshog
Originally Posted by Alabamaslammer
I have a laydown bracket on mine and everything fits fine over top. I have the rack,but I believe its the same clearance underneth with the trunk or rack, besides that you have more clearance with the laydown
Kind of true.. but with the tour pack the cross member for the pack comes right across where the top of the plate is. You can still use the standard lay down but you will have to give it a bend backwards (pushing it towards the front of the bike) to give enough clearance. I used the old school tool 2 hands and some muscle and gently pushed it down a little more.
Old May 29, 2011 | 08:47 AM
Chuck1's Avatar
Chuck1
I just bought a HD laydown plate bracket for my 10 FLHTC, which has the detach kit. I'm hoping they say it doesn't fit because of the view. I don't want to bend anything, in case I don't like it.
Old May 29, 2011 | 09:26 AM
hwyhound's Avatar
hwyhound
From the J&P catalog. Don't recall the part numbers, but I have posted on the same thing before...
Changed tail light with downward facing tag light lense and bracket for tag. works great. About a 15 minute or so install...
The standard bulb WILL melt this lens. I was advised by J&P customer service to replace the standard bulb with the LED alternative.
Old May 29, 2011 | 10:05 AM
shortride's Avatar
shortride
I mounted a 2009 Road King tail light and license plate setup.
hypecat
2014-2024 Touring Models
11
Feb 23, 2020 08:45 AM
xcbullet
Jul 8, 2016 08:38 PM
BikerGent
Jun 30, 2009 06:57 PM
RODEO
Mar 4, 2009 08:17 PM
rerb95
Oct 29, 2008 12:20 PM
