Looking for IDS sproket
Old Oct 7, 2009 | 12:52 PM
FLHXXHLF's Avatar
FLHXXHLF
Default Looking for IDS sproket
I'm trying to find someone that might have a used Isolated drive system sprocket they want to sell. Or where I can get one at a good price. Harley wants way to much. Thanks for the help.
Old Oct 7, 2009 | 01:38 PM
SteveB FLH's Avatar
SteveB FLH
If you can't find a used one try Zanotti H-D online sales. I believe mine was under $200. They will also press in bearing for a minimal charge.
Old Oct 7, 2009 | 02:17 PM
FLHXXHLF's Avatar
FLHXXHLF
Press in bearings ????? What do you mean ?
Old Oct 7, 2009 | 03:38 PM
SteveB FLH's Avatar
SteveB FLH
The IDS has a bearing that is pressed into the center for axle. They (Zanotti) pressed in mine for a nominal fee. You need to specify that at the time order is placed. They are used to this request. Also keep a periodic check of bearing. There has been a few posts of earlier bearing failure with some of the first ones done, I believe. Also keep check of isolators and there is a service bulletin that explains. Use search (on forum) to find out about both. I installed mine about 12.000 mi. ago with no problems, just check it regularly when doing service.
Old Oct 7, 2009 | 03:41 PM
FLHXXHLF's Avatar
FLHXXHLF
Thankyou for the help.
Mikind7
Sep 28, 2010 07:49 AM
sparky_mo
Nov 2, 2008 08:51 AM
acedantinne
Aug 8, 2008 02:30 PM
Dennydp
Nov 13, 2007 09:31 AM
iclick
Aug 14, 2007 10:32 PM
