107 inch build question
Old Oct 7, 2009 | 04:52 PM
hog95023's Avatar
hog95023
Default 107 inch build question
I was told about Chris Rivas by a guy I met at the Reno Street Vibrations last month. I checked out his web site and noticed saw he is offering a 107 build http://chrisrivasvtwin.com/crvts_003.htm
It seems to be very reasonable in price. I am very new to this sort of thing and wanted to get some opionions. I live about 2 hours away from his shop. Do you think this is would be a good way to go or should I pursue another route.
Old Oct 7, 2009 | 05:21 PM
Indianspringsaz's Avatar
Indianspringsaz
I love my 107. Huge difference.
Old Oct 7, 2009 | 05:34 PM
UltraKla$$ic's Avatar
UltraKla$$ic
Do it. However, regarding that builder in which I know nothing about but for the sake of relaying info, I don't see cams and the goods to change them out in that quoted price, not to mention you'll need a tuner, A/C, and pipes. $$$
Old Oct 7, 2009 | 05:39 PM
hog95023's Avatar
hog95023
my bike currently has the D&D FatCat, PCV and the HD air filter. I will need to get another airfilter system though.
Old Oct 7, 2009 | 06:37 PM
PhilM's Avatar
PhilM
I'm not sure I follow the info on his site.... The link states 107 kit & cams "installed" for $2500. Cams are not named, so it's difficult to say how it might perform.
The "technical" link takes you to a 103 build that's closer to $4500. It also includes a tune, but no tuning device.
I have never heard of these guys, but I'm not out that way much either. They may be the best... I dunno.
One observation from the dyno section.... The 107 dyno sheet makes nice "peak" numbers, but the power is not in the RPM range you typically ride in:
Peak Torque: 114 @ 4500
However.... ~80 @ 2500
~90 @ 3000
Pay attention to the RPM range you "typically" ride in and see if this suits your needs.
I built an HQ98 several years ago that made 111 ft/lbs @ approx 2250 and stayed there till about 5k RPM.
You may wanna drop by and chat with them. You should be able to get a reasonable "feel" after an initial visit.
Old Oct 7, 2009 | 06:55 PM
prodrag1320's Avatar
prodrag1320
Default 107
he was selling cylinder kits on ebay,he`s boring the cylinders on a bridgport mill,not a real good way to bore cylinders(if the quill to table is out .005 at the top,it`ll be more than .020 at the bottom of the bore).he dual plug heads in the same mill by tilting the head of the mill,then he trams the mill back to 100% straight to bore cylinders???!!!we dont use "whatever" to do machine work,seen alot of shops boring cylinders in lathes,mills or just honing .010,.020 or all the way to twin cam conversions,we(and any REAL harley machine facility) have the proper equipment to do the machining job.find a well equip shop that uses the proper equipment & machines to do the job RIGHT,or you`ll pay once for s**t work & pay again to have it done right,we`ve had to fix (or try to fix)motors that where not done properly by so called "machine shops"
kirby
vee twin racing
Old Oct 7, 2009 | 06:57 PM
hog95023's Avatar
hog95023
Thanks for the info guys.
Old Oct 7, 2009 | 07:00 PM
prodrag1320
Default 107
just looked at his website,100hp out of a 107" motor!!!,nothing i`de be bragging about
kirby
vee twin racing
Old Oct 7, 2009 | 07:36 PM
qtrracer's Avatar
qtrracer
Don't know anything about his shop but the guy is a great drag racer as he has won a NHRA prostock bike national event last year and was in the countdown to one last year.
troop
The Dyno Room
Feb 16, 2017 09:44 AM
VETERAN75
Apr 27, 2016 01:04 PM
Kokes58
Oct 15, 2012 08:57 PM
marty442
Exhaust System Topics
Jan 7, 2011 05:33 AM
sheldong
Jun 22, 2007 03:04 PM
