Now that I have a stereo setup on my EGS, which by the way sounds great, I was curious if anyone had taken the next step to insulate the outer fairing.
If so was it a product that is marketed or did you perform a DIY mod...like adhering fiberglass to the fairing.
I'd be very interested in any insulation mods that have been performed and sound quality changes that resulted. Would also like to get opinions on whether or not this mod would be worthwhile.
I have heard of some guys using this, and I myself would like to use it when I go to put in my aftermarket speakers. Have read it will increase bass response. Good luck and post your results when you make your choice
A cheaper alternative to the Dynaxorb are mouse pads - similar in size and material - to accomplish the same function. and suggested by FireCap.
Does it work? Yes, it reduces vibration in the outer fairing which suggests the backwave pressure is reduced significantly. However, it's not a dramatic (i.e. "WOW, I can't believe the difference!!!) change IMO.
J&M includes a foam product in their 7.25" speaker kits to do the same thing as the Dynaxorb, which suggests these products serve a purpose.
I installed the DynaXorb pads behind the fairing speakers, mounted on the outer fairing. They did make a difference in clarity and bass response with the Hogtunes speakers and amp. These pads have the consistency and feel of a rubber worm lure, fairly dense and very rubbery, that are fixed to the inside of the outer fairing with superglue.
I bought them here, which at the time was the best price I found ($27 including shipping).
I put the ARC amp and 6-1/2's in my EGC and a friend works at a Super Stereo Center that puts in those damned super "BOOM-BOOM-THUMP-THUMP" sound systems and he gave me a box of what they use in their set-ups. Was a black like tar stuff with a sticky backing. Cut it with a carpenters knife. Sticks like hell!!!!!!!!! It seemed to make the bass clearer but not too much of a real difference. It was free though!!!!!!!
So only two pad of the DynaXorb would be needed and adhered to the outer fairing behind the speakers?
Correct you need the Dynaxorb speaker pack 2 6 inch squares, glue them to the outer fairing right behind the speaker. You can also use any closed cell foam, such as a mouse pad
Yes, the kit comes with two pads that are about 6" square. I found that the tube of super-glue that came with the kit wasn't enough, or maybe I was using too much, so I would advise having a second tube available before installing.
I hadn't thought about using mouse pads, but the rubbery stuff they use for the DynaXorb mats isn't like any mouse pad I've ever used. As I said before it has the feel of a worm fishing lure, and is denser than the mouse pads I've used. I'm not saying mouse pads won't work as well, but the rubber material doesn't feel the same.
While researching options for the fairings I found a lot of information and some good looking products . Not an inexpensive endeavor but could be worth consideration.
I found interesting the different products for , one) dampning, and two) for insulating.
