help me..2010 FLHTK exhaust
Old Oct 13, 2009 | 07:53 AM
ncpitaly's Avatar
ncpitaly
1st Gear
Question help me..2010 FLHTK exhaust
hi i am marco,i live in italy and my english is non good,i have bought a FLHTK and i want change the collector because there is the catalytic that do very warm........is this parts screamin eagle 66848-09 ok for my bike?
I think no only for the position of the sensors...have you some news or know other parts to recommend to me? lot thanks marco
Old Oct 13, 2009 | 09:02 AM
Stansuski's Avatar
Stansuski
Contact Fuelmoto they have non-cat headpipe for 2010.They are a sponsor on this site.
Stan
Old Oct 13, 2009 | 11:08 AM
boom23's Avatar
boom23
From what I know, all 2010 collectors (headers) have catalytic converters, including screamin eagle... Your only choise will be aftermarket like FuelMoto (http://www.jackpotmufflers.com/headpipes.htm).
Old Oct 13, 2009 | 11:19 AM
geezerglide1's Avatar
geezerglide1
Marco,
I also have a 2101 FLHTK and in the process of working on the exhaust. As some have mentioned Fuel Motto another option is to slice apart the header near the middle be careful not to cut into the O2 sensors, take an air chisel and remove the CAT and then reweld header back together. A company called Fullsac does this, however they are in Arizona.
What I intend to do is have the CAT removed from the Header Pipe and go with the Supertrapp Fatshots Mufflers, Andrews 54H cams and a retune using HD SEST or Mastertune TTS.
Doing this over the winter, which is basically here now (Calgary) temperature right now -8 deg C and just had 8 cm of snow.
geezerglide
Old Oct 14, 2009 | 02:02 AM
ncpitaly's Avatar
ncpitaly
1st Gear
thanks to all
Old Oct 14, 2009 | 02:36 AM
ripper43's Avatar
ripper43
Marco if you wait a month you will be able to buy head pipes from Vance & Hines and help your heat issue.
Old Jun 7, 2010 | 08:20 PM
Jambon1's Avatar
Jambon1
I was told that the 09 headers will fit the 2010 and that there is an extension for the O2 sensors. This will allow you to run the cooler 09 headers and remove the 2010 headers with the catalytic converter all together. Any confirmation on this??
Old Jun 7, 2010 | 09:11 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
using 09 headpipe u would also have to adapt the new o2 sensors they are smaller than the ones on the 09.
mstrobes
Touring Parts
Nov 19, 2018 10:05 PM
harley0711
2014-2024 Touring Models
Jul 27, 2018 11:31 AM
roadking2014
Feb 4, 2015 09:06 AM
ggerline
Touring Parts
Jun 3, 2013 09:44 PM
