auto compression releases
Old Dec 26, 2009 | 11:32 PM
  #41
SKYCLIMBER's Avatar
SKYCLIMBER
Choose manual or auto. I went through 4 starters on my 103 build. ACR would have kept it out of the shop when I would rather been riding.
Old Dec 27, 2009 | 07:42 AM
  #42
SUPRPIG's Avatar
SUPRPIG
Default Wise Move!
Originally Posted by chasswartz
I went with the manuel CRs because of the extra cost of the ACRs and my local dealer did not have the fixtures to drill/tap for the ACRs. I also installed the SE compensator and used a .030 cometic gasket. The engine is together just waiting for dry roads and 40 or higher temps to break it in. I have fired it up to check for oil leaks or odd noises, no leaks and sounds good. No good weather in site-bummer.
Thanks for all the input.
Congratulations... you won't be able to wipe the smile off your face when you ride it... especially after it is broken in.
Old Dec 27, 2009 | 07:58 AM
  #43
rapz's Avatar
rapz
I have the ACRs and no problems yet, either way w/the 103 and cams you need them. Good riding!
Old Dec 27, 2009 | 09:59 AM
  #44
gregbenner's Avatar
gregbenner
UK, not sure I really follow.... If the pistons are to low, wouldn't this reduce compression? Does thst cause detonation?
greg
Originally Posted by UltraKla$$ic
Lastly, PLEASE reconsider using a stock harley head gasket since you are going to have the heads off anyways. The '07's are known to have the pistons 0.009" down in the hole, so if you use the stock 0.053" head gasket you are more than likely going to have to retard the timing so much to prevent detonation it will kill the goal of going big bore. Measure the deck height(it only takes 5 minutes) and set it with the proper Cometic gasket and you'll be golden.
NONE of these suggestions would inconvenience you or your builder. Simple "mods" to optimize your build.
Old Dec 27, 2009 | 08:41 PM
  #45
nytryder's Avatar
nytryder
I asked rhe dealer that did my 103'' build about the CR and they stated it was not required. I have had no issues with starting hot or cold. Could be I'm just lucky. If I pull the heads again it could be a good idea to install the manual CRs. A chromed high torque starter is $545.00 plus labor to replace a bad starter. Stock is 1.2 KW and the high torque is 1.4 KW so it seems to be a fairly thin line between the success / failure of the starters on the bigger bores.
Old Jan 3, 2010 | 01:05 PM
  #46
oscarg's Avatar
oscarg
Originally Posted by marcparnes
I have auto compression releases on my '09 with stock heads. No problem.
Marc
Can anyone tell how much auto compression release is costing with dealer installing
jurgie
Exhaust System Topics
11
Mar 23, 2014 08:20 AM
rollnthunder
Feb 1, 2012 11:48 PM
lt1tyrell
Aug 22, 2011 10:00 PM
fireaxxe
Feb 2, 2011 06:08 AM
ozzie65
EVO
16
May 31, 2009 09:10 AM
