Manual Compression Release Failure
Old Oct 18, 2009 | 05:41 AM
masterblaster's Avatar
masterblaster
Default Manual Compression Release Failure
I just did a 107 motor have a compression release not locking shut when I crank the motor now. It takes e blipping the throttle to get it to shut. Anyone know what can cause the MCR to fail or not shut properly? Anyone have this happen?
Old Oct 18, 2009 | 06:04 AM
Lonewolf176's Avatar
Lonewolf176
It's just a little dirty. You can clean it or just blip the throttle. It's pretty common, and I wouldn't worry.
Old Oct 18, 2009 | 07:53 AM
Indianspringsaz's Avatar
Indianspringsaz
Mine does the same 1 out of 5 times. No biggie.
Old Oct 18, 2009 | 07:56 AM
timberland's Avatar
timberland
From: Log home in SE Michigan full time. Log cabin in east TN, Smoky Mountians part time
carbon / dirt build up...yep its common. Remove the release and spray brake cleaner or starting fluid in it to clean it. Reinstall and it will be fixed.
1flhtk4me's Avatar
1flhtk4me
My rear cyl. does it once in a while.You can remove it and soak with PB Blaster or Tri-Flow.
Old Oct 18, 2009 | 08:02 AM
UltraKla$$ic's Avatar
UltraKla$$ic
bump the compression to 13.5:1..........that'll fix it!
Old Oct 18, 2009 | 08:33 AM
lkr0's Avatar
lkr0
+1 just hit the throttle
Old Oct 18, 2009 | 08:35 AM
maineultraclassic's Avatar
maineultraclassic
Take it out, soak it in some carb cleaner over night, spray it out with an air gun, and lube it up with some of your favorite lube, then reinstall.
That should fix it for a while, then you'll probably have to do it again.
Steve
Old Oct 18, 2009 | 08:54 AM
brettnbama's Avatar
brettnbama
Steve
So astro-glide will work?
Old Oct 18, 2009 | 08:56 AM
UltraKla$$ic
Steve
K-Y?
