primary fluid question..
Old Oct 22, 2009 | 07:34 PM
  #31
robbie52's Avatar
robbie52
No way would I use ATF in the transmission. I prefer 75W-90 synthetic gear oil, instead of 20W-50 motor oil.
Old Oct 22, 2009 | 07:52 PM
  #32
imrotton2's Avatar
imrotton2
i would get a manual for your bike, to be sure.. too many crazy responces ... ive read most of um, and now im confused... 10w40 dino in primary -----gear oil in tranny ----20w50 in the primary
Old Oct 22, 2009 | 07:55 PM
  #33
goutieboy's Avatar
goutieboy
put 32oz of screamming eagle syn3 in.adjusted everything and all seems ok,just gotta reassure myself i did it correctly. will ride a few miles and recheck. thinkin maybe i did have a cable hang up and maybe the clutch was a lil loose read the trick on how to adjust the clutch and gonna do it in the next few days(always wondered if my seat of the pants fill was the right thing)seems more logicial when i read the thread on how to do it. that way at least there is a guide line....thankx to all
Old Oct 22, 2009 | 08:26 PM
  #34
ssls6's Avatar
ssls6
Originally Posted by bamorris2
No, he said he's using RP Max-Cycle 10w-30. That is motorcycle-specific oil that is approved for use with wet clutches.
Sorry, missed that.
Old Oct 22, 2009 | 09:52 PM
  #35
NoCoLoco's Avatar
NoCoLoco
The problem I have with the manual is that it only recommends Formual+ or SYN3 in the tranny and primary. Gear oil works better in both of those (IMO) so I will not use SYN3 and I can't get a straight answer as to what exactly Formula+ is, I'm not a big fan of magical mystery oil. The way I see it, in order for Formula+ to be compatable in the primary it can't be any heavier than a 90w gear oil (IF it is a gear oil) which in my opinion is a little too light for the tranny. And yes, I do realize Harley-Davidson transmissions are designed and tested using Formula+ but I'm still not sold on that stuff.
Old Oct 23, 2009 | 12:25 AM
  #36
emwolb's Avatar
emwolb
do not use 75/90 or any other gear oil in your primary. regular 20-50 dino oil will work just fine, and i've heard of many using atf, although i've not used it in the primary. i have been using royal purple 20-50 max cycle also, but i do believe it is allowing the clutch to not have as much grab as the dino 20-50. the heavy weight 75-90 is only for use in the trans, not the primary. i use 75-140 royal purple in my trans, and it shifts sweet, is not noisy at all. great stuff, but only for the trans, not for the primary.
Old Oct 23, 2009 | 03:16 AM
  #37
captjon37's Avatar
captjon37
After reading all this I think you should be safe with anything that comes in a plastic bottle with the word "Oil" on it.
Old Oct 23, 2009 | 04:36 AM
  #38
Sandcrab's Avatar
Sandcrab
Default What he said
What he said X 2
Old Oct 23, 2009 | 05:29 AM
  #39
JRSULTRA07's Avatar
JRSULTRA07
Most new cars and trucks have ATF fluild in manual trans. Also race bikes use atf fluid alot of times its made for clutches. In my 07 ultra classic ATF syn worked better than mobil 1 syn had a little slippage with mobil 1, but i use mobil 1 in the other 2 holes
Old Oct 23, 2009 | 08:11 AM
  #40
smokindave's Avatar
smokindave
Amsoil in all 3 holes every 5K miles.
