06 Ultra rebuild
http://s207.photobucket.com/albums/b...z/Micks124SnS/
This album has come pics of my build. The motor is really strong in the mid range, and then get her up on the cam and she screams.
I still havent done a custom map, I am running the S&S canned map that cam with the kit. She is quite lean in the mid range, and too rich up high, but even so is running 124hp / 123 tq. Next service we are gonna build a custom map and she should be in the 130s.
At the strip with the screen on and tools in the bags we weighed 1050lb and the best run was 12.25 @108mph, so she is quick as. Once the remap is done she will be in the 11s. I have put a shift light on her now and that helps get the best out of the motor.
Have a look at the pics - the quality of the forgings and machining is excellent. The triple valve springs and drilled retainers are very neat, their roller rockers and forged supports look the biz. Just a quality kit wherever you look.
We added a feulling cam support plate and oil pump too, which I would advise as a wise choice of your 06. The fuelling pump has 20% more supply and 60% more scavenge than the stock pump, and the plate is much stronger with much larger oil galleries than stock.
Are you going to go with an S&S VFI system, carby or SE induction???
In an older motor (pre-07) I'd suggest adding the Screaming Eagle hydraulic tensioner upgrade. The kit comes with the new high volume oil and a much beefer cam plate. To install the S&S gear drives you just don't install the tensioners. You can get the whole kit for about $350 which is cheaper than just the fueling oil pump...
