Problem mounting back rest
Old Jan 27, 2010 | 06:39 PM
Trikerjon's Avatar
Trikerjon
Arrow Rider backrest mounting bracket
If you decide to sell the bracket, I`m looking for one...........cheap, free or reasonable.
Old Jan 27, 2010 | 07:07 PM
lp's Avatar
lp
Originally Posted by Stryke1
I purchased a riders back rest and mounting bracket from Chicago HD for my 2005 Road Glide. Part #'s 52900-09A & 52587-09. The mounting bracket has 4 different holes for attachment. This allows the backrest to be mounted further foreward or back as desired. My problem is that I can only use the 2 forward mounting holes. This puts the backrest too far forward. If I try to use either of the two rearward mounting holes, the seat pan hits the mounting bracklet and I can't install the seat. Has anyone else encountered this problem? Have you found a way to mount the barcket further back? I have 3 different seats and I have the same problem with each. Is it possible that I have the wrong mounting bracket for a RG? Thanks for your help.
Lots of guys have this problem. They end up bending the backrest itself rear-wards to give them room.
lp
Old Jan 27, 2010 | 07:30 PM
piasspj's Avatar
piasspj
I seem to recall a few years ago that some people were bending the post on the backrest to get it to sit further back. Sorry I don't remember the exact situation.
Old Jan 27, 2010 | 11:15 PM
Stryke1's Avatar
Stryke1
Thanks for the idea. I'm going to look tomorrow to see what it would take to bend the post on the backrest and if that would solve the problem.
Old Jan 28, 2010 | 08:32 AM
piasspj's Avatar
piasspj
Did you see this thread as well?
https://www.hdforums.com/forum/touri...-backrest.html
Old Jan 28, 2010 | 09:37 AM
stro1965's Avatar
stro1965
I had to put a lot of heat on mine to bend those suckers, they are HARD.
Old Jan 28, 2010 | 10:21 AM
kyote's Avatar
kyote
I have a new bracket I got with my backrest..I already had a bracket on my bike and I didnt install it...if you want to try it you are welcome to..I work in WA so you can stop by and pick it up if you are interested.. Its just laying around and of no use to me..
Old Jan 28, 2010 | 01:56 PM
Dandy1's Avatar
Dandy1
I ran into the same problem on my 07 RK. I put a 1/2" spacer inbetween the brackets and used a longer bolt. This will lean the backrest back. You will have to find the correct hole for mounting it to the fender by mounting it forward a little because the backrest will lean back more.
Old Jan 28, 2010 | 03:50 PM
Stryke1's Avatar
Stryke1
Hey kyote - Thanks for the offer. I may take you up on that. I'll probably wait for a couple of months to seriously tackle this as the bike is stored and covered up for the winter. There were a few other suggestions about spacers, washers and a longer bolt that I will also ponder once I get back at it.
Old Jan 29, 2010 | 08:52 AM
kyote's Avatar
kyote
sounds good.. may take me a cpl months to remember where I "stored" it..lol let me know..
doug62
Nov 22, 2016 07:25 PM
T K Glider
Mar 24, 2011 10:04 PM
Candubrain
Nov 8, 2010 08:07 PM
Biff_H
Jan 24, 2009 12:27 PM
