Fyi
Old Nov 9, 2009 | 06:06 AM
hoytheld's Avatar
hoytheld
Default Fyi
I changed the rod ends on my stock shift linkage over to heim joints....that was the easy part. Upon doing this work... I noticed the verticle rod that connects the transmission to the shift linkage was loose....no problem, the pinch bolt was loose right? Wrong...the bolt was tight as a *****...naturally. So...after cussing out this bike again....and thinking this winter was going to be packed-full-of-fun yanking off the primary to replace that little arm...I calmed myself down and thought of an idea.
I took the bolt out of the arm (5/16" x 24 allen head cap screw). Low and behold there was a section of the threads that were wiped out....so I got a tap to chase the threads in the arm.....everything felt good when chasing (didn't get hung up or break the tap!)
I put in a new bolt...tightened it down...and presto...problem solved!
So...keep this in your arsenal of fixes...and keep an eye on that linkage arm!! If the splines in that arm get wiped out....you will have a very...very bad day!!
Old Nov 9, 2009 | 07:57 AM
DocHarley's Avatar
DocHarley
Personally, I'm happy when my bike breaks, I enjoy working on it. Next time you break down let me fix it.
Old Nov 9, 2009 | 08:08 AM
paguy's Avatar
paguy
Thanks. I'll keep in mind for future reference.
mechanicalman
Oct 21, 2015 09:21 AM
pt4u2nv
Sep 25, 2015 02:04 PM
ponesma
Jul 15, 2014 09:15 PM
scooter_trash_1
Oct 12, 2010 06:51 AM
HOG_0308
Aug 8, 2010 08:54 PM
