Horn mostly broke...
Old Nov 19, 2009 | 08:34 PM
TurkeyRun's Avatar
TurkeyRun
Default Horn mostly broke...
2009 EGC. Got cut off the other day, hit the horn and got nothing. When I stopped later, with the bike off, I can barely hear a "beep". So, it's not totally dead, just way more useless than normal.
Before I take it into the dealer and waste a day (or more) getting a warranty fix. Any suggestions?
Thanks
Old Nov 19, 2009 | 08:40 PM
mastery's Avatar
mastery
Yeah. HD horns are POS devices. They always fail when you really need them. Get a MiniBeast horn, they work great, stylish, and are loud (and work). Stay away from any horn made by HD (even their air horn, another POS).
Old Nov 19, 2009 | 09:14 PM
RKKY's Avatar
RKKY
Before heading into the dealer I would try using some silicon spray under the cover. Usually fixes the symptoms you are describing.
Old Nov 19, 2009 | 09:28 PM
jberg's Avatar
jberg
POS Mexican horn will be replaced under warrantee. Dealers all know about them.
BoomerBob's Avatar
BoomerBob
I put one of these in when I noticed my horn getting to sounding puny. Plug and play. They are so inexpensive I bought two.
Old Nov 19, 2009 | 09:46 PM
old.gezr's Avatar
old.gezr
Hey BoomerBob, where did you put it?
Old Nov 20, 2009 | 12:34 AM
txfxstrider's Avatar
txfxstrider
Did you wash your bike, or get the horn wet lately. My '07 horn quits for a couple of days when it gets wet and then works normally after drying out.
Old Nov 20, 2009 | 12:45 AM
kgjl's Avatar
kgjl
That is a great price on the FIAAM horn. I paid $16 for the same horn at the auto parts store. It is a great horn.
It bolts on right where the factory horn goes.
Old Nov 20, 2009 | 09:59 AM
TurkeyRun's Avatar
TurkeyRun
Well, haven't washed it, but ridden to-from work in the rain a bunch lately.
I'll squirt some silicon spray in there and if that doesn't clear it up I'll assume God is handing me an upgrade opportunity :-)
Thanks all!
Old Nov 20, 2009 | 10:22 AM
rh8234's Avatar
rh8234
I had a ground wire behind the cowbell break. before the wire was completely busted, the horn sounded weak. When the wire finally broke completely, of course horn was dead. re soldered the wire and all is good.
