compression???
Old Jul 11, 2006 | 09:07 PM
blk06rk's Avatar
blk06rk
Default compression???
Anybody running 10 or 10.5 to1 compression? having any problems? pinging? over heating?
Old Jul 11, 2006 | 09:21 PM
Blue SOG's Avatar
Blue SOG
Default RE: compression???
I'm running 10.5:1 and ping if it's over 90 two up IF I get on it too much without downshifting. Heat was looking like it "might" be a problem so I installed HD's super premium oil cooler. I should have done that a year ago. I love the thing and highly recommend it. As for the pinging... I just take it a little easier under those conditions. The bike is a 05 FLHTCi 95 cu in with forged pistons, SE heads and SE 211 cams.
Old Jul 11, 2006 | 09:24 PM
jeepster09's Avatar
jeepster09
Mine don't ping with 10.44 to 1 compression ratio.
Old Jul 12, 2006 | 09:52 AM
100thRK's Avatar
100thRK
I'm running 10.5:1 with no pinging. I installed HD's super premium oil cooler with motor build. Motor has nearly 10,000 miles on the build with no problems, no pinging, no over heating but it does spit a little oil. Just enough to be annoying.
Old Jul 12, 2006 | 12:17 PM
PhilM's Avatar
PhilM
Properly tuned, there are plenty of cams that will allow a build to run 10+:1 w/o pinging.
THat said, there are more cams that will not run @ that CR w/o pinging NO MATTER what you do. It's all about "matching" the components of your build and getting it properly tuned.
BLK ~ do you have a 10+:1 build and it is pinging (if so, what cams) or just inquiring?
Heat can be managed with good oil and a good oil cooler. TC engines are designed to withstand a lot of heat as it is.
Old Jul 14, 2006 | 03:56 PM
GliderXXX's Avatar
GliderXXX
Had 10:1-1 on my 03 Fatboy with SE Head ,Flat Tops and Woods gear drive cams. As long as I was using 91 and better gas no pinging. In fact I only remember it pinging once when it was 107 and I didn't gear down properly. A proper tune, and good matching components and you shouldn't have to worry. I will add though, that my reason for staying below 10:5-1 was for that reason.
Gliden
Exhaust System Topics
13
Sep 30, 2011 06:06 AM
speakerfritz
May 29, 2011 10:52 PM
Dyna_in_the_works
Dec 3, 2010 12:31 PM
echo4tango
11
Jul 26, 2009 09:08 AM
chuckyp
Jul 8, 2006 01:01 PM
