SE Heavy Breather - Compact
Old Nov 22, 2009 | 08:34 PM
scooby doo's Avatar
scooby doo
Default SE Heavy Breather - Compact
I see they offer the compact Heavy Breather for those looking to put it on the lowers.
Has anybody put it on yet?
What are the specs? I'm sure it's shorter but by how much?
If it's on a bike can you post a pic.
Old Nov 23, 2009 | 11:53 AM
Runamuck's Avatar
Runamuck
I have one on the way, supposed to be here Wednesday. I just put vented lowers on my RG and had the regular heavy breather on. Looks like it needs to be about an inch and a half shorter. I'll know on Wed.
Old Nov 23, 2009 | 12:17 PM
Biggzed's Avatar
Biggzed
Couldn't you have just got a shorter filter element? K&N has a lot of generic ones to choose from. Did they change the snorkel on the compact SE version?
Zach
Old Nov 23, 2009 | 12:20 PM
qtrracer's Avatar
qtrracer
A shorter element will probably reduce air flow by the way.
Old Nov 23, 2009 | 12:43 PM
Biggzed's Avatar
Biggzed
Could, but as long as the total surface area is similar it should not be a problem. Keep in mind most aftermarket filters have the ability to flow more than our engines need. There was a test on this done by one of the mags a couple of years ago. I can't remember which one though.
Here is a helpful link to finding custom filters. Just calculate how much surface area you want and start looking.
http://www.knfilters.com/universal/universal.htm
Zach
Old Nov 23, 2009 | 02:51 PM
qtrracer's Avatar
qtrracer
Yes you could try for a shorter bigger diameter one but then we start the will it hit my leg thing. Plus I would have thought if it was easier and cheaper to use a different filter HD probably would have gone that route rather than produce 2 different AC units.
Old Nov 23, 2009 | 02:57 PM
Runamuck's Avatar
Runamuck
The filter element on the model that works with lowers is supposed to be shorter. All the other parts are the same.
Old Nov 23, 2009 | 03:03 PM
qtrracer's Avatar
qtrracer
Thumbs up
Let us know what you found out on Wed.
Old Nov 29, 2009 | 06:43 AM
scooby doo's Avatar
scooby doo
So did the compact Air Cleaner go on?
Post a pick if you get a chance. I'm sure others thinking about lowers would like to see a shot.
Old Dec 8, 2009 | 08:14 PM
HOGWYLDPR's Avatar
HOGWYLDPR
I have the compact heavy breather because of my lowers with glove boxes. When I tried to put it on, it did not fit,the intake tube is still too long. Anyone else have the same issue?
